CRX DX Plus...........EFI swap/further questions
Old Sep 20, 2006 | 05:50 AM
Karlwallerartist's Avatar
Default CRX DX Plus...........EFI swap/further questions
A few weeks back I posted a question about swapping an Si EFI mainfold onto my '90 DX. I recieved some informative answers (thanks for helping the Noob guys)but they sort of brought up other questions.
In my original post I said that I would like to keep the auto and asked what type of ECU I needed. Several replies came back, one of which involved an Accura integra ECU and another with a Civic. I am currently searching for both.
I am looking for as much "plug and play" as I can get (ie I'm not wanting to get too down and dirty with splicing and dicing harnesses). If I went with the Civic ECU would it be best if I used that particular harness also?
As an aside, the manifold I recieved did not have the injectors!
Crap!
I can pick up new Accell injectors (part # 110-151255 )from Jeg's for about $66.00. anyone have experience with the Accell's?
Old Sep 20, 2006 | 06:56 AM
wickedEFguy's Avatar
Default Re: CRX DX Plus...........EFI swap/further questions (Karlwallerartist)
First off man if you need injectors hit up a local junk yard and look for a 88-91 CRX/hatch. The easiest way to tell if it is MPFI or DPFI is to look in the upper right hand corner of the engine bay. Your looking for a silver box that has a green plug which looks like this:
Cut from the plug attached to the shock tower harness in the engine bay. All you'll need to do is re-pin and add 2 wires 2 to your stock plug and you'll be able to use all the orginal wires.
Old Sep 20, 2006 | 07:34 AM
3s0n3's Avatar
i got one ... buy it
daniel-crx
May 4, 2009 11:14 AM
japish
Aug 30, 2006 06:25 PM
RareSI
Nov 10, 2004 05:06 PM
rice is nice
May 12, 2004 09:21 PM
CRXBoy
Apr 2, 2002 07:12 AM
