Oxygen sensor OEM or Bosch, Honda TSB Purge Kit & New Injectors, what is this?
Old Sep 20, 2006 | 05:06 AM
cemdauber's Avatar
Default Oxygen sensor OEM or Bosch, Honda TSB Purge Kit & New Injectors, what is this?
Two years ago an excellent Honda repair shop in Seattle recommend that I change out the Oxygen sensor and install a Honda kit consisting of a purge kit (I have no idea what this is?) and 2 injectors. They said that Honda put out a TSB recommending replacing the 2 injectors with this new purge kit and 2 new injectors. They also mentioned something about the new purge kit having a reduced orifice. I have searched all over the web and can only find this link which is not very helpful http://www.tec-help.com/Honda_PGM-FI.htm
1989 Honda Civic 3dr DX 1493 cm3 Honda PGM-FI Throttle Body
Questions:
Oxygen sensor- What symptoms notify you that your oxygen sensor is bad? Is there any difference between buying a Honda OEM oxygen sensor $199 and a bosch universal oxygen sensor for $20?
Does anyone know anything about a TSB recommending replacing the 2 injectors with this new purge kit and 2 new injectors? TSB number and part numbers would be helpful. Also symptoms of a bad injectors.
Thanks Mike
Old Sep 20, 2006 | 07:06 PM
mahatma's Avatar
Default Re: Oxygen sensor OEM or Bosch, Honda TSB Purge Kit & New Injectors, what is this? (cemdauber)
I've used a Bosch o2 sensor with no troubles at all. To hell with a $200 one!!!
Never heard of an injector recall.....if it ain't broke.....
Are you having problems with fuel delivery or gas mileage?
A problem with o2 sensor or injectors should trip your check engine light either way.
Old Sep 20, 2006 | 09:34 PM
cemdauber's Avatar
Default Re: Oxygen sensor OEM or Bosch, Honda TSB Purge Kit & New Injectors, what is this? (mahatma)
I think the car drives great. Maybe a little hesitation during highway acceleration, I have not been tracking fuel economy. It does go through mufflers about every 4 years. My 2001 muffler does not have any holes yet but the tail pipe rotted off so that I had to remove the crome tip before it fell off, but I figured this probably because I do a lot of very short drives (2 miles) and the exhaust system never really warms up. The check engine light has come on in the past a couple of times but only when I drove it right onto the highway after work. Now that I know where to find the codes I will have to pull up the carpet and check it out next time. In the past I just turned off the ignition off then on the highway and the check engine light disappeared.
Here is a link to a page I found on oxygen sensors. Everything you wanted to know about them and how to test them.
http://www.wps.com/LPG/o2sensor.html
akandok
Apr 8, 2011 05:29 AM
SeVeNisOnE
Oct 26, 2008 03:43 PM
9SECQTR
Jul 3, 2004 08:31 PM
