Has anyone tried a H22 vtec head swap to an H23?
Old Apr 30, 2002 | 12:55 PM
Smurfylude's Avatar
Default Has anyone tried a H22 vtec head swap to an H23?
Just wondering if anyone has tried it on this board. I have some quesitons for you. Thanks.
Old Apr 30, 2002 | 02:01 PM
vpforeva's Avatar
New User
Default Re: Has anyone tried a H22 vtec head swap to an H23? (Sushi X)
no
Old May 1, 2002 | 05:24 AM
PrecisionH23a's Avatar
do not do this hybrid, it is highly unreliable. lets just say it took (i forgot their name) 3 motors before they got this head swap running right.
Old Jul 6, 2002 | 02:27 AM
jarel's Avatar
Default Re: Has anyone tried a H22 vtec head swap to an H23? (GudeH23a)
gude...just curious. but since you say it is unreliable...but whoever finally got it running right...is their set-up reliable or working?
[Modified by chyknees, 11:27 AM 7/6/2002]
Old Jul 6, 2002 | 09:42 AM
ichibanjap's Avatar
Default Re: Has anyone tried a H22 vtec head swap to an H23? (chyknees)
Sushi X, I have talked to a couple of people that have done this swap with no problems. One guy told me to take all the components that the timing belt touches on the H22 and swap it over to the H23, And you have to plug a hole on top of the block. Anyways I will let you know how the one i'm doing goes, when it is done.
Go to hondaplex.com, it has a how-to but I don't think it went well for this guy, but just to give you an idea of what you need
Old Jul 6, 2002 | 12:03 PM
prospeed's Avatar
I ran that set up 4 years ago. It ran just fine. I switched back to H22a for higher rpms so i can't really tell you bout longevity.
Old Jul 6, 2002 | 02:31 PM
quik2kSi's Avatar
a friend of mine ran that motor in a 93 H/B. he had I/H/E and ran 12.6 at gainesville,fl.
Old Jul 17, 2002 | 11:19 AM
Charlie Moua's Avatar
Default Re: Has anyone tried a H22 vtec head swap to an H23? (quik2kSi)
one of my friends has a h23 with h22vtec head in a 95 accord ex 4door. he's spent alot of money and time trying to make it run right. Last week he only ran a 16.4(which is a fast as my stock crx si) I's sad... but in his words(I'm in it too deep to just give up with my hybird" I hope he gets it running right.
Old Jul 17, 2002 | 01:10 PM
Smurfylude's Avatar
Default Re: Has anyone tried a H22 vtec head swap to an H23? (Charlie)
I ended up going JDM H23vtec
Old Jul 17, 2002 | 01:58 PM
jarel's Avatar
nice you planning to go turbo? or NA?
*I just remembered that a successful h23vtec swap was from atomic/import builders. Jeff had a h23vtec in his civic for a number of years and it was running reliable. just a thought.
Old Jul 17, 2002 | 03:09 PM
fastludeh22's Avatar
you can just put h23 crank and rods in a h22, same priceable but much easier
Old Jul 17, 2002 | 07:56 PM
Smurfylude's Avatar
GE sleeved with Turbo on the way
Old Jul 17, 2002 | 08:53 PM
ichibanjap's Avatar
Damn you spent alot of money on that swap, yea? Or did you get a good deal? Anyways let us know how everything turns out..
Old Jul 18, 2002 | 07:56 AM
Smurfylude's Avatar
Default Re: Has anyone tried a H22 vtec head swap to an H23? (ichibanjap)
yea my wallet hurts....I'll keep you guys posted
Old Jul 18, 2002 | 10:34 AM
prospeed's Avatar
How is it coming along over there? Let me know when you get everything together on your motor !
Old Jul 18, 2002 | 10:50 AM
Smurfylude's Avatar
Default Re: Has anyone tried a H22 vtec head swap to an H23? (prospeed)
Thanks Brian,
I'm getting the block honed and the crank had to be centerline bored and balanced since there were no markings on it....The alternator stud was also bent when it got here....
Old Jul 18, 2002 | 06:55 PM
prospeed's Avatar
Hi sorry bout that UPS sucks. Are you sure its not the A/C stud? There are 2 at the bottom. The alternator does not have studs. Well im glad things are coming along. Let me know if you need anything else or help with anything. Thanks!
Old Jul 19, 2002 | 06:57 AM
4bidden's Avatar
w0w, youre the first one that ive heard of that's goin to run that motor. what tranny are you going to run with it since they only came with autos in japan?
Old Jul 19, 2002 | 08:01 AM
Accord94DX's Avatar
Default Re: Has anyone tried a H22 vtec head swap to an H23? (4bidden)
Probably a USDM or JDM H22a tranny.
Old Jul 19, 2002 | 08:07 AM
Buckkaaaa!!'s Avatar
New User
Default Re: Has anyone tried a H22 vtec head swap to an H23? (Accord94DX)
yeah checkout Importbuilders in Fullerton..... if anyone can pull off a reliable swap its them...
Old Jul 19, 2002 | 08:12 AM
2point6's Avatar
I am build an h22/23 hybrid. So far it is working out great. The oil squirters from the H22 have been placed on a h23 block and the h23 crank has been Balanced. The rods are h23 and pistons are type SH. This is very similar to the "Top Secret" stroker kits availible from Japan, except they have slightly more compression (type s pistons) and their cranks are ceramic coated. The only weak link I am worried about is the cylinder sleeves. They are stock. This engine has a higher rod ratio than my current stroker, so it should last for a while, but depends on how High the thing will be reved. I plan to rev it to 8000 RPM.
Old Jul 19, 2002 | 11:07 PM
Fly1865's Avatar
Default Re: Has anyone tried a H22 vtec head swap to an H23? (2point6)
SO the piston speed is not a factor in all this. I thought the speed of the piston was the major issue with the 2.3/vtec. That the piston would be moving at such i high speed it would melt the sleeve. Please let me knoe, I'd like to learn more about this. e-mail if possible about your findings. Thanks.
Old Jul 20, 2002 | 06:57 AM
2point6's Avatar
Default Re: Has anyone tried a H22 vtec head swap to an H23? (Fly1865)
piston speed is a huge factor, but if my "stroker" which has a lower rod ratio can handle the Revs and last, then this one should do the same.
Old Jul 20, 2002 | 10:00 AM
BoostedH23a1's Avatar
piston speed? wtf wouldnt that be rpm? i dont know im a moron. anyway what does h23vtec dyno at stock? how did u put in the oil squirters?
Old Jul 20, 2002 | 10:47 AM
bb1turbovtec's Avatar
Top Secret does not make anything for our cars! You must be mistaken. If you mean Top Fuel kit the crank is also ballenced.
[Modified by bb1turbovtec, 7:49 PM 7/20/2002]
