More Wiring Problems ... Yippe!
I went to honda and looked up where all my battery cables are supposed to be run, power and ground. So I hooked them all up where they need to go. However, when I connect the power cable to the battery, then I try to do the same with the ground, and it archs (sparks) BAD! However, if I disconnect the cable that runs from the wiring harness to the fuse box (shown below), I am able to connect the cables to the battery no problem. I have no idea why. What do you guys think? I'm really stumped once again, since I'm not the greatest with wiring and that's where most of my problems arise from.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slomies »</TD></TR><TR><TD CLASS="quote">that's part of the grounding kit. i believe it went straight to the ground on the battery. i pulled the grounding kit off because that's what was causing the problem.</TD></TR></TABLE>
that's what i was getting at.
glad you got it
glad you got it
