auto to stick conversion for EG... will it fit 96-2000 civic??? need yer help...
Old Sep 19, 2006 | 02:39 PM
JDMike_DB8R's Avatar
From: FR Mobbin up on 1 n left hand shiftin n da FF in, killa so cal again, US
Default auto to stick conversion for EG... will it fit 96-2000 civic??? need yer help...
<FONT SIZE="2"><FONT COLOR="brown">Okay, I've searched and found nothing on the questions I'm about to ask, so yeah. I currently have an auto to stick conversion for an EG. I have done quite a few auto to stick conversions and they were converted with parts from manual vehicles of the same type. What I need to know is if the pedal assembly from the EG will fit my 97 hatch??? I think the hardline from the clutch master cylinder to the slave is a little different, (feel free to correct me if i'm wrong), and I think the slave assembly itself is different. I have the tranny from an EG. I know that the tranny will bolt up to the stock motor, but is there any goods or bads about using an EG tranny on a newer 96-2000 civic D-series motor? It would be a lot easier for me if I were to just buy the stuff off of a 96-2000 civic, but I'm strapped for cash and I'm on a tight budget at the moment. It's only a DD, so I don't want to spend too much money on it. Any feedback would be appreciated. Negative comments will try to be ignored. Thanks in advance...</FONT></FONT>
Old Sep 19, 2006 | 02:41 PM
Default Re: auto to stick conversion for EG... will it fit 96-2000 civic??? need yer help... (JDMike_DB8R)
oh yeah, BTW... I already have the tranny mounts on order for the 96-2000 civic, so yeah, that's one thing I knew I was going to need.
Old Sep 19, 2006 | 08:28 PM
does anyone know if any of the parts can be used other than the tranny?
Old Sep 19, 2006 | 09:50 PM
Luserkid's Avatar
Everything will work EXCEPT, the auto to manual trans mounts thats needed for 92-95 (you need a 96-00 top tranny mount), and the clutch hardline (there different on 92-95 and 96-00, easy fix with a straight SS line). Everything else is a direct bolt on.
Old Sep 20, 2006 | 07:14 AM
Default Re: auto to stick conversion for EG... will it fit 96-2000 civic??? need yer help... (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">Everything will work EXCEPT, the auto to manual trans mounts thats needed for 92-95 (you need a 96-00 top tranny mount), and the clutch hardline (there different on 92-95 and 96-00, easy fix with a straight SS line). Everything else is a direct bolt on. </TD></TR></TABLE>
sweet, thanks for the info.
dem0nk1d
Jun 7, 2007 11:08 AM
daheavyking
May 5, 2007 08:49 PM
armygsrcivic
Dec 31, 2006 11:46 AM
T_bones
Jun 11, 2006 03:41 PM
eg ferio
Nov 29, 2003 06:20 PM
