b16a vtec problem codes 17 and 23
the car is a ef civic hatch with a b16a in it it uses a obdo pr3 ecu and it is flashing 2 codes VSS #17 and knock sensor #23 the car has a hyrdo tranny so it is newer than obd0 and the ovd0 ecu need a mechanical vss and the hyrdo uses a electronic vss is htere any way to make it work properyl so i can pass aircare and have vtec engagement thanks.
