EF to EG ECU
Hi! I would like use EG series ECU instead of the EF series that i am using now. I am driving an EF9 with original EF harness. Will need the actual EG series ECU socket info to successfully swap my EF wires into.
Any kind souls out there?
You have a couple of choices here. One is to buy a pre-made ECU adaptor. The other is to cut your old ECU plugs off and solder on 1992-1995 ECU plugs. I made a chart some time back on the hybrid board of resource.crx.org which outlines this change. But I am not sure how you would find it.
Chewy Built !
Nov 17, 2007 06:11 PM
JDM_DOHC_SiR
Aug 6, 2001 05:42 AM
