Gasket Kit - Are all b-series gaskets interchangeable?
Hey Guys,
Been searching forever to no avail.
I have a b16a1 block, b18c1 head, and I'm about to get a b18c5 OEM gasket kit for 97-98, 00-01 TypeR. Now I know the HG and IM gaskets are interchangeable between b-series, however, the kit comes with a lot of things:
# Cylinder Head gasket
# Intake manifold gasket
# Exhaust manifold gasket
# 8 Valve cover grommets
# Valve cover gasket
# 4 Spark plug tube seals
# Cam plug
# 2 Cam seals
# Distributor O-ring seal
# 8 Intake valve stem seals
# 8 Exhaust valve stem seals
# Intake & Exhaust orifice O-rings
# 2 Engine Exhaust "A" pipe gaskets
Are all of these things interchangeable between b-series? Will they work with my setup?
Thanks!
# Cam plug
# 2 Cam seals
Thanks!
only thing that is not interchangable there is the intake mani gasket. You have a gsr head which uses a completely different gasket. All other parts are the same.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Runnerdown »</TD></TR><TR><TD CLASS="quote">only thing that is not interchangable there is the intake mani gasket. You have a gsr head which uses a completely different gasket. All other parts are the same.</TD></TR></TABLE>
Runnerdown, sweet thanx for the heads up, yea I confused the interchangeability between B16 and B18C5... I'm getting an Outlaw Engineering Thermobloc kit anyways, and it'll be for a C1 so I'll be using that IM gasket and TB gasket... Thanks!!
Anyone else care to confirm?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPD DMN »</TD></TR><TR><TD CLASS="quote">Anyone else care to confirm?</TD></TR></TABLE>
Confirmed. Some kits have the gaskets for both.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbogixxer »</TD></TR><TR><TD CLASS="quote">
Confirmed. Some kits have the gaskets for both.</TD></TR></TABLE>
Tubrogixxer, much appreciated...
itr1235
Apr 11, 2007 08:02 PM
prostreetonline
May 3, 2006 04:36 PM
prostreetonline
Jan 19, 2006 09:46 AM
rasinhell
Jan 24, 2005 09:44 AM
jbell
Jan 7, 2005 01:56 PM
