**Please Help: JDM Stanley Fog Light Installation**
I have the jdm stanley yellow fog lights with only the harness that connects to the back of the lights. Can anyone direct me to a previous DIY link or offer advice as to what else i may need? Thanks
You will need the Interior harness and switch.
08V31-SR3-30009 SWITCH, FOGLIGHT
08V31-SR8-10007 WIRE HARNESS, SWITCH
The only difference with the USDM harness and switch is that it won't light up amber (which can be done very easily), and the fogs won't turn on with just the parking lights and will turn off with the high beams. Then, you'll need to run a single wire from the exterior harness through the firewall to the interior harness to give the lights power.
Here's a parts list (you won't need a lot of the stuff listed).
http://www.hondaautomotivepart....html
Here's how you cut the bumper.
https://honda-tech.com/zerothread?id=1352749
The relay is universal and the switch could be obtained from any online site or just about anywhere......My problem is obtaining the harnesses which honda claims isnt made anymore (obsolete)...has anyone tried to do the quick wiring? Instead of using a harness, just connecting one ground to the frame & the other wire to the switch? ...........
or
or
ITLNstallion818
Aug 14, 2007 09:20 AM
FinallyGotMine
Jun 22, 2006 12:39 PM
