pressed in liners an 88mm pistons h22a???
was thinkin on going this route.
h22a block
pressed in liners
an possible 88mm pistons
im able to get eagle rods an wisco 88mm piston for $350(balanced). ive been talking with some people an they say why not use pressed in liners so i can use a forgered piston. GOOD IDEA!! You get these for about 250 or so installed. just wondering if im able to go 88mm on the block.
comments....
h22a block
pressed in liners
comments....
Machine work is what costs...there has also been some thinking on inserts from the Mercedes Benz 87-89mm may be compatible?
RaceEng.com I believe also sells a cheaper alternative of sleeves for the FRM but machine costs for me was way over the cost of them...
my liners are pressed in and i have a 88mm bore thre great for all motor setups or mild boost i also have weisco pistons.. dont scimp on the rods though ive had eagle rods and they did not last to long. i would recomend crower pro billet rods thats what i am running... any more questions pm me
eagle rods didnt last to log? looks like something wasnt put together right.there rated for 600hp. did u have H beams??
im planning running 12 psi or so. goal is 300-350whp. i was told today that i would need to use wiesco rinngs? is that correct? also i was also told the rist pins arent very strong.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DrivinVtec »</TD></TR><TR><TD CLASS="quote">eagle rods didnt last to log? looks like something wasnt put together right.there rated for 600hp. did u have H beams??
eagles HP rating for their rods is a joke.. bc rod strength isnt measured in HP, its more of tensile strength vs RPM vs pressure vs force, e=mc^2 u get the picture
ive ran 450 whp spinning 8500 rpms out of eagles. but i still suggest u get something like crowers or pauters, cause once u have 350, you'll want 550, trust me.
and remember what i said about using shitty sleeves: https://honda-tech.com/zerothread?id=870704
im planning running 12 psi or so. goal is 300-350whp. i was told today that i would need to use wiesco rinngs? is that correct? also i was also told the rist pins arent very strong.</TD></TR></TABLE>
yes h beams...no it was put together like it should have been, there just really crappy rods, there made of crappy steel from china ... and as for that pictures of the liners breaking (in the post above with link) like i said they are good for an n/a build i have heard night mares about boosting with drop in liners... and yes use the weisco rings.. and false there wrist pins are excelent... dont take my word though look around at all the cars using wiesco... hope this helps
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DrivinVtec »</TD></TR><TR><TD CLASS="quote">damn man 90mm bore. ****. im doing 88mm. this is a street car an where i live 300-350 would wax almost everything here. that sux it happened to you</TD></TR></TABLE>
ya it was my daily driver back then also. no 90 mm wasnt done for fun, other things in the past forced that. but i still feel it was the brand, and not the bore(not that that helped) that caused it to blow...
but no fear that was my old setup, new one is 88 mm and done right. i put over 1000 mi on it in 3.5 days already: https://honda-tech.com/zerothread?id=1756232
pm me i have a lot of parts for a turbo build, but were not going to talk about that in this post...
