VIDEO: All Motor Coupe - A couple low 13's
Old Sep 19, 2006 | 10:42 AM
D-Rob's Avatar
Default VIDEO: All Motor Coupe - A couple low 13's
Some of you guys may remember my post in here back in March after I ran 13.17 @ 104.9mph in my LSVTEC '98 Civic coupe.
Well, here's a video (finally) of two passes that day.
The setup was:
B18A block (Hot-tanked, decked, painted, bore'd 0.25mm over, honed)
89mm crank (micropolished and balanced)
ACL main, rod, and thrust bearings
Stock rods w/ ARP rod bolts
P30 0.25mm OS pistons
ITR main caps (2, 3, 4)
ITR block girdle
ITR oil pump (new), water pump (new)
GSR timing belt
All new gaskets/seals
Golden Eagle 82mm LSVTEC kit
PR3 head from 2000 Civic Si (Hot-tanked, planed, painted)
Skunk2 valvesprings, retainers, cam gears
Skunk2 Pro2+ cams
No port/polish
All new seals
ACT HD/SS
ACT StreetLite flywheel
S4C transmission
DriveShaftShop Stage 1 axles
AEBS intake manifold
Password:JDM intake manifold gasket
AEM fuel rail (not that it really does anything...)
RC 370cc injectors
65mm JG/Edelbrock throttlebody
AEM cold-air intake
DC Sports JDM 4-1 header (2.5" collector w/ skidplate welded onto bottom)
MSD SCI
NGK Iridium plugs
Test pipe
DC Sports 2.25" catback
Tuned with Crome by 93turbo16 ( http://www.j-k-tuning.com ) to 185whp/129wtq
Since then, I've added an RMF narrow header, SMSP 2.5" exhaust, and AEM 3" CAI. That resulted in 195whp/131wtq.
I hope to go back to Cecil County Dragway on October 28th, and try for a 12-second pass.
So, without further ado, the video:
http://www.youtube.com/watch?v=5H-EDZD-Ktc
Thank you,
- Derek
Old Sep 19, 2006 | 10:54 AM
realis9's Avatar
Default Re: VIDEO: All Motor Coupe - A couple low 13's (D-Rob)
wow u ran 13.1 and trap 104.9 with under 200 whp? 185 whp? that is impressive. What was your 60" was the car gutted?
Old Sep 19, 2006 | 10:57 AM
D-Rob's Avatar
Default Re: VIDEO: All Motor Coupe - A couple low 13's (realis9)
1.95 sixty-foot, and no, the car is not gutted at all.
This run was made with full exhaust, no rear seats, and no subwoofers.
The only weight reduction done to the body of the car was removed bumper supports and carbon fiber hood.
And as far as the trap speed vs. dyno numbers... Let's just say the dyno I use reads a little lower than the Honda-Tech standard dyno.
Old Sep 19, 2006 | 05:24 PM
D-Rob's Avatar
What, no one likes videos anymore?
Old Sep 19, 2006 | 06:30 PM
DOMKID's Avatar
wow! impressive times. What elevation is that track?
Old Sep 20, 2006 | 03:58 AM
D-Rob's Avatar
Default Re: VIDEO: All Motor Coupe - A couple low 13's (Felix.)
380 ft. I think?
Old Sep 20, 2006 | 05:52 AM
93supercoupe's Avatar
thats sweet, I had a similar car and motor, i wonder if it was that fast?
And my name is also Derek
Good job man, sweet car.
Old Sep 20, 2006 | 08:06 AM
steve1320's Avatar
nice car and nice video
Old Sep 20, 2006 | 06:58 PM
vg7z's Avatar
nice vid...but i cant hear nothing!
Old Sep 25, 2006 | 09:48 PM
Honda Bull's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Felix. &raquo;</TD></TR><TR><TD CLASS="quote">wow! impressive times. What elevation is that track?</TD></TR></TABLE>
330 feet. Maryland.
Old Sep 25, 2006 | 11:03 PM
CiviCoupeKb20's Avatar
Wow, great times!!
Old Sep 26, 2006 | 12:14 AM
dc5tegk20's Avatar
cant wait till the 28th the c00pe is gonna rock and then were celebratin lol
Z0831xiz
13
Nov 6, 2017 04:00 PM
D-Rob
607
Nov 14, 2015 10:32 PM
ek9800
Nov 20, 2006 10:56 PM
ek9800
Oct 31, 2006 10:51 AM
CRVTEC0WNZJ00
44
Jul 26, 2006 09:20 AM
