Exhaust leak form header...need help
Last night i installed the Jdm ITR header onto my b16b and now have a leak where the header bolts up to the engine...I replaced the gasket torgued to specs but still no go...any ideas how to get the leak to stop? would some sort of high temp gasket sealer work? Please help i hate having a car that sounds like a beefed up lawn mower. I know this isnt really N/A discussion but could really use some help.
check the rivets in the gasket... i had a problem like that n cut out all the rivets in the gasket n it seemed to work fine for me.... don't forget to use high temp gasket sealant....
the rivets arent even on the part that seals.....
you can try using high temp sealant but thats always temporary, machining it would fix it for good....
i still fail to realize how this was placed in the all-motor forum....what does this have to do with all motor other than the fact that you dont have a turbo??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phatch99 »</TD></TR><TR><TD CLASS="quote">check the rivets in the gasket... i had a problem like that n cut out all the rivets in the gasket n it seemed to work fine for me.... don't forget to use high temp gasket sealant....</TD></TR></TABLE>
Rivets? where can i find high temp gasket sealant? Autozone or something...do you know what its called
kabob
Mar 4, 2003 02:16 PM
