Broken Key, Help!!!!!
Old Sep 19, 2006 | 09:45 AM
sir2sol's Avatar
Default Broken Key, Help!!!!!
alright, last night i pulled a really dumb move and ended up breaking my key off in my ignition. i've done several searches and found that the easiest way to get the broken key out is by removing the lock cylinder and just taking the hunk of key out. my question is how do you remove the lock cylinder? i know that i have to have the switch in the #1 on position and push a button to remove it. where is that button? i've searched everywhere on the switch and can't find it. any help would be really great. thanks in advance.
Old Sep 19, 2006 | 09:57 AM
cxSHOE's Avatar
Default Re: Broken Key, Help!!!!! (sir2sol)
there will be a small pin hole on the top part of the ignition.you stick the key in turn it onces then push the pin down and pull out the cylinder. see if you can get it out with some tweezers. a key shop can still cut you a key even though its broken. or at honda with your vin#
Old Sep 19, 2006 | 11:12 AM
sir2sol's Avatar
Default Re: Broken Key, Help!!!!! (cxSHOE)
cool, thanks. problem solved
kevinhughes13
Jul 28, 2013 11:18 PM
1sikhatch
Apr 8, 2010 08:58 AM
dgdarien
Oct 2, 2008 06:24 PM
racingcrx
Jul 4, 2008 01:07 PM
full Circling
Jun 17, 2005 01:34 PM
