oem headgasket
Old Sep 19, 2006 | 04:33 AM
d16dcoe45's Avatar
Default oem headgasket
I just have a question about oem hg's. I planning on putting together a new d16a6 with 0.020" over pistons--75.5mm, my question is do the oem hg's, specifically the d16z6 hg have a big enough bore to accomodate 0.020" over, or will I have to go with Cometic or something like that? I notice Cometice sells both a 75mm HG and a 75.5mm HG--I would prefer to use a d16z6 oem HG but I just want to make sure the bore on the HG is big enough.
Old Sep 19, 2006 | 10:09 AM
NathanMorris's Avatar
Default Re: oem headgasket (d16dcoe45)
I believe you can put up to a 0.5mm over piston in (0.020" over) without any issues. Looking at mine right here, this is a true statement.
Nathan
Old Sep 19, 2006 | 12:44 PM
d16dcoe45's Avatar
Default Re: oem headgasket (NathanMorris)
Cool, thanks for the info. Yeah, I have 4.3cc dome, 75.5 (0.020" over) SRPs going in, I read somewhere else that a stock oem gasket will accept up to 0.020" over--I would much rather use the d16z6 oem HG (0.037") which is like half the cost as a 75.5mm 0.030" Cometic--I trust the oem HG over Cometic anyday of the week--although I have never really had a problem due to the HG with a Cometic....
purple_civic94
May 17, 2012 03:16 PM
IBriaIN
Jan 7, 2011 12:22 AM
SpoolnG2
Oct 28, 2003 07:30 PM
1CiViC1
Jun 1, 2003 11:33 PM
