Help Me Out, Im Shopping For Cams... But Dont Know What To Get.
Old Sep 19, 2006 | 02:52 AM
VolkswagenWHO!!!'s Avatar
Default Help Me Out, Im Shopping For Cams... But Dont Know What To Get.
Well right now I have a motor that is in the process of being rebuilt with a couple little extra's thrown in. I wanted to do some cams also, preferably Skunk2's. But i dont know which Skunk2's to go with. The motor is a US Spec B18C5 (Type R). When the motor is done it will still be internally stock, except for ARP Rod Bolts, Milled Head (.030), and ARP Head Studs tuned on Hondata S200 on pump gas (93). This is going to be my daily driver, i want something pretty aggressive but not to crazy. I have been told that the Stage 2's would be my best choice. What about the Pro Series cams?
Modified by VolkswagonWHO!!! at 9:27 AM 9/19/2006
Old Sep 19, 2006 | 04:09 AM
esohsee's Avatar
Default Re: Help Me Out, Im Shopping For Cams... But Dont Know What To Get. (VolkswagonWHO!!!)
i would say s2s2, blox2, or bc3. dont forget to upgrade you valvetrain
Old Sep 19, 2006 | 05:16 AM
SMSP's Avatar
http://www.skunk2.com/camOffer.html
Old Sep 19, 2006 | 04:52 PM
BUMP!!!
anymore suggestions?....anyone?
Old Sep 19, 2006 | 06:59 PM
RPRacing's Avatar
i feel the skunk Pro 1 cams will best suit your application with the stock motor. They will provide decent power on that compression ratio and have a strong bottom end. you can look over this thread for some info https://honda-tech.com/zerothread?id=1338293
-Francisco
Old Sep 19, 2006 | 09:27 PM
Tsukuba 699's Avatar
What's you compression ration after the 0.030 adjusment?
you certainly don't want too much cam for your compression...
Old Sep 19, 2006 | 10:29 PM
UncleD's Avatar
Default Re: Help Me Out, Im Shopping For Cams... But Dont Know What To Get. (Tsukuba 699)
This worked out pretty good: https://honda-tech.com/zerothread?id=1603212
Old Sep 19, 2006 | 11:40 PM
after the mill job i should be seeing around 11.8:1- 12:1 at the most
Old Sep 19, 2006 | 11:48 PM
salman's Avatar
http://www.team-integra.net/se...D=371
this will help.
ArmedFelon99
125
Feb 18, 2014 03:35 PM
JakersVa
Jul 7, 2009 04:07 PM
MI4$DC5
Mar 10, 2005 04:34 PM
IMPATIENT
Feb 3, 2005 06:22 PM
