345 injectors big enough??
i am currently running a h22a4 tuned with a p28 on crome. after a tuning session today, we discovered that my puny 290cc injectors are running at about 94% DC. this only occurs up around 8k however. can i get away with using the h22a1 345cc injectors even though they are peak and hold? or should i upgrade to something bigger? will the 290's be ok for now ?? suggestions welcome. thanx
i dont see the need of going bigger than 345cc unless you plan on building the bottom end anytime soon. 94% is pretty dangerous to run at 8k rpms. If anything goes wrong you can say goodbye to a cylinder or two. If you have a fuel pressure regulator, you can raise the psi to lower the DC.
how are you formulating duty cycle? Are you going by what crome says?
if you have everything setup, it can give you an idea of what DC you are running.
you have to make sure your fuel multipliers, displacement and fuel pressure data are all correct in Crome or the formula will be off. Although i dont know how much i trust the values even with everything is inputted correctly.
you got skunk2 cams right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91preyludesi »</TD></TR><TR><TD CLASS="quote">the 440s are peak and hold or saturated or does it matter?</TD></TR></TABLE>
you would need a resistor box to run the JDM OBDI injectors which are 345cc as well with the DSM injectors and most RC injetors
Guest
Posts: n/a
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec »</TD></TR><TR><TD CLASS="quote">if you have everything setup, it can give you an idea of what DC you are running.
you got skunk2 cams right?</TD></TR></TABLE>
nope game time decsion and i went with crower stage2's.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec »</TD></TR><TR><TD CLASS="quote">you would need a resistor box to run the JDM OBDI injectors which are 345cc as well with the DSM injectors and most RC injetors</TD></TR></TABLE> damn i thought so.
oh well whats money anyway.
madcitylude: thanks for the links
oh well whats money anyway.madcitylude: thanks for the links
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91preyludesi »</TD></TR><TR><TD CLASS="quote">nope game time decsion and i went with crower stage2's.
damn i thought so.
well then yea, i can see your car running around that duty cycle. With that header, cams and tuning your really gonna be putting some stress on those injectors.
damn i thought so.
</TD></TR></TABLE>well then yea, i can see your car running around that duty cycle. With that header, cams and tuning your really gonna be putting some stress on those injectors.
yea that sux i shoulda just gotten bigger injectors to begin with. now i gotta buy injectors and pay for a retune. i didnt think i would be putting down enough power to stress them past 85% or so. think they will be ok for a lil bit. i am rarely going to rev up to 8k anyway. i've only done it once since the tune and it backfired from the 3rd to 4th shift.... whatever that means
hmmm maybe i'll just get a fpr. you are running 290's right??. BTW im gonna try and get you my bin to see if that helps you out at all with your tune. im hitting the dyno in a couple weeks so i will keep you updated
to be honest i didnt think i'd need one. i never expected to come that close to maxing out the injectors. i also thought of the fpr as kind of a hack. ya know? why not get bigger injectors and tune for them if you got the program.
gotta admit though a fpr sounds a lot more tempting then buy new injectors and wiring up a resistor box
^^ i didnt know you could. the last time i had to deal with bigger injectors was when i turboed my 3rd gen. but i already had a resistor box so i all i had to do was throw in some 450 dsm blue tops and i was good to go.
I'd suggest you get bigger injectors before you jack up the FP. I only went the way I did because the bigger injectors I was going to get turned out to be...290 Prelude injectors, and I didn't really have any more time to kill. Nearly 60psi is definitely unkind to the injectors and is also pretty much the limit of the stock pump.
Unless you're going no farther with your engine, and have a pressing interest in the OBD2 computer running the car at times (state inspection, w/e)
Modified by A Blue Lude at 10:48 AM 9/19/2006
