CEL 4 Crank Position Sensor.... how to fix??
Well heres the delema. My buddy swapped in a d15b jdm motor in place of his z6. He was running the p28 ecu but couldnt chip it so he got the p08 ecu. He is using the z6 harness and z6 dist. Now the p08 ecu throws 4 blinks when checking the CEL. That means code 4, Crank Position Sensor. Is that sensor located in the distributor??? How do i go about fixing it???
Im wondering if we put the d15b dist on, do you think it will fix the problem??
Anyhelp appreciated cause im clueless right now.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by unbelievableEG »</TD></TR><TR><TD CLASS="quote">you dont have to have the p28 chiped to run the d15b vtec</TD></TR></TABLE>
well we decided to run the p08 ecu and its thrownin this code, any help??
lilvpimp305
Feb 18, 2012 05:26 AM
mikej94civex
13
Dec 17, 2009 12:55 PM
