Wiring 99-00 SI cluster in 99 DX
Old Sep 18, 2006 | 06:43 PM
Danethomp's Avatar
Default Wiring 99-00 SI cluster in 99 DX
searched and couldnt find anything this specific. ive got a 99 DX which does not come w/ a tach on the cluster. so im swapping in an SI cluster. what is the right way to wire this so it looks OEM and not a single wire running across the engine bay. any links or input would help. THANKS.
-Daniel
Old Sep 18, 2006 | 06:44 PM
SkoundrelUSA's Avatar
cute little bastard
Default Re: Wiring 99-00 SI cluster in 99 DX (Danethomp)
lol wtf? You don't need to wire anything its plug and play. All the harnesses are prewired to read the Tach.
Old Sep 18, 2006 | 07:47 PM
cambopheonix56's Avatar
Simply remove dx and install si.
Old Sep 18, 2006 | 07:48 PM
Danethomp's Avatar
i guess its all jacked up cuz the tach didnt work when i first installed it and i hiad to run a single wire from the driver side by the shock tower across to the dizzy where there was a cut wire...weird. thanks anyways for the help.
Old Sep 18, 2006 | 07:52 PM
nighttrain33's Avatar
Default Re: (Danethomp)
Your cluster didn't have a tach in it to begin with, did it? I didn't think that DX clusters did.
-Shane
Old Sep 18, 2006 | 09:53 PM
joker4096's Avatar
i put an ex in my cx, just plug and play. since you said you had a cut wire in the engine bay, then that's where your problem was. shoulda been plug and play besides that
Old Sep 18, 2006 | 11:56 PM
JimDCXC's Avatar
Default Re: (joker4096)
it should just plug in and work,
hondanube2010
Jun 30, 2010 05:10 PM
SlaMMedB16
10
Dec 17, 2007 09:21 AM
opiumdaze
Aug 10, 2005 01:25 PM
gondzur
Aug 30, 2004 08:24 PM
kent
Mar 2, 2003 06:23 PM
