slight shaking under hard acceleration
Old Sep 18, 2006 | 05:10 PM
Tatakai's Avatar
Default slight shaking under hard acceleration
the car feels like its shaking a bit under hard (over 1/2 throttle) acceleration, LS in a EG coupe with no lower torque mounts. wheel bearings? (please tell me im wrong)
also, for some reason sometimes when i turn the ignition, it just does a single click, and if i just keep turning it over and over it'll eventually start up no problem. loose starter wire?
Old Sep 18, 2006 | 06:27 PM
PyroProblem's Avatar
Default Re: slight shaking under hard acceleration (Tatakai)
The shaky feeling under accel sounds like it might be your cv axles. I think this is a symptom but im not 100%.
The clicking intermittently sounds like your starter is dying. It will eventually get to a point where it wont start at all...
You can take it apart,clean,and lightly touch up the contacts which will help sometimes. I did this to mine when it started going bad and it lasted over another year until i broke off the B+ stud whe doing a swap once...
Good luck!
Old Sep 20, 2006 | 07:29 PM
Tatakai's Avatar
Default Re: slight shaking under hard acceleration (PyroProblem)
(sorry to bring this back, but i forgot i even made it, lol)
thanks for the info- my starter ended up having a loose connection that visually looked fine.. but tugged on the positive lead a little and it moved all around got the car with a fresh swap, no biggie.
and the axles.. when i got it, he told me something about how the car has ABS, and he pulled a couple fuses because only one side has an ABS axle? dunno if its possible really.. the brakes are GSR upgraded to drilled/slotted rotors, i believe ABS as well. could the shaking be from a non ABS axle in a ABS rotor? or is it not even possible to work? sorry, i don't know much about ABS (as far as the special parts)
Old Sep 21, 2006 | 03:42 PM
Tatakai's Avatar
just one bump..
Old Sep 21, 2006 | 04:11 PM
Lewy. Dee Ayy's Avatar
..cant help you but..is that guy in ur sig for real..or was it a joke?
Old Sep 21, 2006 | 04:14 PM
YodajdmEK4's Avatar
Default Re: slight shaking under hard acceleration (WhiteOut)
For the shaking I am thinking axles or wheel bearings and for the click it could be the loose wire on the starter or your main relay may be going out
mawkiemarc
May 12, 2006 01:50 PM
EJ1 wilcox
Apr 25, 2005 02:25 PM
Race Egr
Jan 31, 2005 01:18 PM
crx1856
Aug 20, 2003 10:24 PM
elpermgrande
Aug 9, 2002 06:43 AM
