Single disc clutch
Can any of you guys give advice on a good singal disc clutch for a h22.It will only be a weekend warrior so it's not a daily d.Looked at the spec but really need some advice from people that have more experience in this department...THANX
Needs to hold about 650whp.
Modified by ProPerformance at 7:07 PM 9/18/2006
the spec clutch holds up... i just dont like the fact that its an unsprung hub.. lots of clutch chatter.. be prepared for some clutch riding at first.. ive had mine for a year and i still find myself having to ride the clutch sometimes... overall.. i wouldnt get it again.. just stick with exedy =]
not sure what power you run but i run a solid 6button sinted clutch with double diaphram pressure plate in a heavily modded d16! 360 hp on the wheels so i recon if you do the same with tripple diaphram or even exactly the same you should be good!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vaporboy12 »</TD></TR><TR><TD CLASS="quote">a single dick clutch will not hold that much power. well it might for one or 2 rips</TD></TR></TABLE>
i never knew they made one...
