Type S cams with Turbo charger?
Old Sep 18, 2006 | 10:22 AM
preludedriva's Avatar
Default Type S cams with Turbo charger?
I heard stock cams were better if i was to turbo the h22 in my prelude
i also heard just the intake cam will do as well if i turbo anyone clarify?
Old Sep 18, 2006 | 10:35 AM
md23vtec's Avatar
Default Re: Type S cams with Turbo charger? (preludedriva)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preludedriva &raquo;</TD></TR><TR><TD CLASS="quote">I heard stock cams were better if i was to turbo the h22 in my prelude
i also heard just the intake cam will do as well if i turbo anyone clarify?</TD></TR></TABLE>
I am not really clear on what your asking.... but yes type-S cams will work great with turbo as well as stock usdm cams
Old Sep 18, 2006 | 10:37 AM
Chuckles99SH's Avatar
Default Re: Type S cams with Turbo charger? (md23vtec)
A cam with too much overlap eg a NA cam would be bad for turbo.. but the Type-s arent that aggressive so it would work but i think most prefer the stock usdm cam.
Old Sep 18, 2006 | 10:44 AM
md23vtec's Avatar
Default Re: Type S cams with Turbo charger? (Chuckles99SH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chuckles99SH &raquo;</TD></TR><TR><TD CLASS="quote">A cam with too much overlap eg a NA cam would be bad for turbo.. but the Type-s arent that aggressive so it would work but i think most prefer the stock usdm cam.
Thats actually false. Some guys who really rev there cars out love all motor cams dialed in right they can pick up over 60 whp peak HP. I have seen it done.
The reason I say stock usdm cams are good is because they have great power threw the entire powerband. Type-S is slightly more aggressive and will give you great results also.
Old Sep 18, 2006 | 01:21 PM
from, what i was told having a exhaust type s cam would be bad for turbo i forgot the exact reason
Old Sep 18, 2006 | 05:09 PM
ExplicitSpeed360's Avatar
Banned.
The thinking behind using the type S cams for turbo is same as B series thinking for turbo...it works and is proven that type S cams do work for mild to medium turbo build...
GSR cams...ITR cams...CTR cams...
USDM H22A cams...JDM H22A cams...JDM H22A Type S cams...
Old Sep 18, 2006 | 06:07 PM
93hatched_projekt's Avatar
Default Re: Type S cams with Turbo charger? (ExplicitSpeed360)
Ditch the idea for type s cams , tons of h22 guys are making 600whp on stock h22 cams. I would spend your money else where.
Old Sep 18, 2006 | 06:22 PM
md23vtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preludedriva &raquo;</TD></TR><TR><TD CLASS="quote">from, what i was told having a exhaust type s cam would be bad for turbo i forgot the exact reason </TD></TR></TABLE>
Thats a load of crap. Sorry no other way to put it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93hatched_projekt &raquo;</TD></TR><TR><TD CLASS="quote">Ditch the idea for type s cams , tons of h22 guys are making 600whp on stock h22 cams. I would spend your money else where.</TD></TR></TABLE>
This is also correct My lude makes 612whp/425tq on stock cams, but.... if he does get the type-s cams they wont hurt the car is the point I was making
Old Sep 19, 2006 | 06:08 AM
Turbo Lude SH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by md23vtec &raquo;</TD></TR><TR><TD CLASS="quote">
Thats actually false. Some guys who really rev there cars out love all motor cams dialed in right they can pick up over 60 whp peak HP. I have seen it done. </TD></TR></TABLE>
You said it, all motor cams dialed in right will work very well with forced induction, but your not using your engine to it's full potential. Using a cam actually designed for FI will be even better.
High lift long duration cams will make power in any engine, a NA engine will be tuned (cam timing) to achieve a certain degree of overlap. The same cams can be used on a FI engine, but the overlap will be needed to be tuned out to a point. Tuning the overlap out would involve retarding the exhaust cam usually. Although you've gained power over stock cams(due to higher lift/increased duration), your still leaving some power on the table.
The best way is to get a set of cams designed for FI. High lift w/ quick ramp rates and a decent amount of duration and miniumal overlap at 0 degrees advance/retard.
In a nut shell:
Type S cams vs base for FI - Doesn't matter, their almost the same cam anyway.
I'm dead set on buying cams for my FI setup, which ones should I get? - If you're going to spend your money on cams, get a set that is designed for FI.
I already have huge bad *** all motor cams and now I've installed a turbocharger, do I have to change my cams? - No, you don't have to, but some cam gears and tuning will get you gains, but not to the extent of true FI cams.
auto-accessories-inc.
Jul 27, 2007 12:19 PM
pootie.teng
Jan 16, 2007 05:38 PM
VIVAHONDA
Jan 2, 2004 02:32 PM
QCKGSR
Dec 5, 2002 08:12 PM
