Considering Purchasing a 1991 CRX as a Project Car
Hey folks...I've been on around the Honda scene for sometime, but am new to this board.
For sometime, I've played with the idea of buying a project car to work on during the weekends. Some of my choices have been a 200SX, 5th Generation Civic, circa~'93 Integra GS-R, and a newer CRX.
First thing I'd do is do a swap, and the B16C seems like a great candidate, or even the ZC engine. There's no real question here, but I'm sort of overwhelmed as to where to begin, what you'd suggest, and any tips.
I have yet to locate a CRX to buy, but will likely begin looking seriously come this Summer. Thanks for any advice guys!
From: PhantomGrayEH2, CA Where Gay Arnold Rules, USA
Go for it, CRXs are real great cars that are hell of fun to drive. If u want speed go for 88 HF, if your more into looks 88 Si. Just remember the 88s r the lightest CRXs so if u want speed thats the way to go. Good luck
yeah I just picked up an 88 Hf to replace my wrecked 88 Hf
GO FOR IT! If you look around you can find them for pretty good deals depending on where you are
[Modified by MOCrxHf, 1:58 AM 5/1/2002]
im in mass and i'll have a '91 crx si (check sig) up for sale in a couple months when the b18c is done being rebuilt
If I haven't found a car by then, I'll give you a ring.
I wouldn't be too committed to speed...a slow car can be a fun car if it handles well. That said, any car weighing less than 2500 pounds with ~170HP will move like a bat out of hell, so a stripped interior and other weight-saving procedures aren't on my to-do list. Nonethess, thanks for all your help!
EDIT: What are the odds of finding a rust-free CRX? I know older Honda's are prone to rust problems (my 1993 Vigor was plagued by that problem...oddly enough, she was waxed on a monthly basis with this problem in the back of my head, and it STILL rusted). I could always replace panels, etc...but are the newer ones (with the exclusion of the car being younger) less prone to rust; ie better paint?
[Modified by AcuraFanatic, 1:20 PM 5/1/2002]
I wouldn't be too committed to speed...a slow car can be a fun car if it handles well. That said, any car weighing less than 2500 pounds with ~170HP will move like a bat out of hell, so a stripped interior and other weight-saving procedures aren't on my to-do list. Nonethess, thanks for all your help!EDIT: What are the odds of finding a rust-free CRX? I know older Honda's are prone to rust problems (my 1993 Vigor was plagued by that problem...oddly enough, she was waxed on a monthly basis with this problem in the back of my head, and it STILL rusted). I could always replace panels, etc...but are the newer ones (with the exclusion of the car being younger) less prone to rust; ie better paint?
Here's what I'd do:
'85-'87 Si
sticky tires
poly bushings
'86-'89 teg brakes
thicker front torsion bars
rear lowering springs
adjustable shocks
big rear swaybar
front camber plates
adjustable panhard bar
'86-'89 teg motor & tranny
small/medium turbo (somethin like a T3 .48 Stage-II Super-60)
beefy clutch
quaife diff
Whole thing should weigh in around 2100 lbs tops.
P.S. There's no such thing as a B16C.
'85-'87 Si
sticky tires
poly bushings
'86-'89 teg brakes
adjustable shocks
big rear swaybar
front camber plates
beefy clutch
quaife diff
howdy...long time no talk
200sx is actually a heavy platform to work on for a fwd...a crx would be a good candidate
advice...since this is your 1st swap...i'd look into getting a zc (either sohc or dohc) or building up a d16a6 stock crx si engine...this at a better pace gets you into hybrid arena at a much lower costs...a b16a will cost you at least $2,500 if you do it right...plus with a d series you can build a turbo for either for less than $1k...a crx is a great project car and can move quick with a tuned d series with most bolt ons
jaje
ps...what happened to that one site?
jaje
dlric
19
Mar 28, 2004 04:04 PM
NomadMan
20
Mar 22, 2004 11:27 PM
Jepeezy
Feb 21, 2003 05:12 PM
