b16a SC build. Advice?
Old Sep 18, 2006 | 04:55 AM
Grr Wolfe's Avatar
Default b16a SC build. Advice?
My suspension's all together (besides the Cusco FUCA's, still waiting on delivery from Japan ). Time to move on to the motor and i'd love some advice. I put together a list of everything I think I need, the budget is $15k and most of it will be installed and dynoed by Import Builders. I'm hoping to get everything ordered as soon as possible so I can fire my REX down to IB's. I provided links for easier browsing. Please voice any opinions about the list and any parts i've missed or don't fit the b16a, I can never have too much info. Again the primary purpose is road racing. Thanks guys! Couldn't do it without you.
IB B16a Block Fully Built - Link (2nd from top but with stage 2 sleeves)
FYI: Engine is found in the 99-00 civic SI and 94-97 del sol DOHC - Thanks I Got The Juice Now
IB B16a Hydrolic Tranny - Link <-- Worried about a stiff clutch pedal, this should help.
IB Supercharger Kit, 20psi - Link
IB Intake Manifold - Link
Hasport B Mount Kit (hydro) - Link
Hasport Rear Engine Mount - Link <-- Do I need this!?
Hasport B Swap Axles - Link <-- Will these handle 400whp? Can I run better ones with this swap?
AEM Engine Management System - Link
Greddy Timing belt - Link
K&N Oil Filter - Link
AEM Fuel Pressure Regulator - Link
AEM Fuel Filter - Link
AEM Fuel Rail - Link
B&M Fuel Pressure Gauge - Link
Toda Racing Head Gasket - Link
Nology Hot Wire Plug Wire Set - Link
Mobil 1 Full Synthetic Oil <-- After break in.
Exedy Twin Plate SR Clutch Set - Link
Quaife LSD - Link
Omni Power Quick Clutch Master Cycl - Link
RC Injectors - Link
PWR Dual Core Radiator - Link
Greddy Oil Catch Can - Link
Custom Built Oil Cooler - Link
Fuel Lines (stainless steel) and Fuel Filter as detailed in this thread - Link
POSSIBLE SUPERCHARGER AFTERCOOLERS:
Laminova - Link
Vortech - Link
POSSIBLE EXHAUST HEADERS:
Comptech Polished Header - Link
DC Sports 4-1 Stainless Steel - Link
POSSIBLE FUEL PUMPS: (what's the differance?)
Walbro #341 - Link
Walbro #342 - Link
Not sure which sets are ment for my engine. I'm looking for the black versions:
Unorthodox Underdrive Pulley - Link
Unorthodox Pulley Set - Link
Not sure which pan to run:
Moroso Oil Pans - Link
Not sure which ignition parts I really need and what's too overkill:
Ignition Stoof - Link
Which brand intake/exhaust valves??
Random Technology HiFlow Cat - Link
I'm worried that my engine might eat this cat alive. I definitely don't need to run a cat but i'd like to if I can for the sake of the enviroment, call me crazy if you will .
Al19067
Jun 12, 2004 06:53 AM
