JDM 5 lug wheel bearing???
Old Sep 17, 2006 | 10:32 PM
AK94GSR's Avatar
Default JDM 5 lug wheel bearing???
im posting this for a friend, but anyways the question is
is he has a 99 civic si. he just swapped a jdm 5 lug conversion onto it, but he has a drivers front wheel bearing going out.
im assuming the wheel bearings are different for the usdm and the jdm since the axles are different sizes.
anyone know where i could order a replacement or if they are just the same for US??
Old Sep 18, 2006 | 01:43 AM
BlueIntegraBoy's Avatar
Default Re: JDM 5 lug wheel bearing??? (AK94GSR)
I think 97-01 CRV bearings will work since it uses 36mm spline.
44300-S47-008 BEARING ASSY., HUB
Old Sep 21, 2006 | 07:03 AM
AK94GSR's Avatar
Default Re: JDM 5 lug wheel bearing??? (BlueIntegraBoy)
thanks
anyone else have any input
is the only difference of the 5 lug the hub assembly and 36mm splines
is the outer diameter of the bearing/hub itself the same as a normal integra/civic???
Old Sep 27, 2006 | 04:40 PM
AK94GSR's Avatar
bump
94allmotor
Mar 16, 2011 12:47 PM
FRKWOO
Mar 18, 2010 10:43 PM
typer604
Dec 24, 2008 08:43 AM
boostedsol
Dec 26, 2003 06:26 PM
