Buddy Club IV B18c setup, what pistons???
I have a BC IV cams and valvetrain in my Jdm ITR motor, I am replacing the head with a ported GSR head and swap everything into it. I wanna see what's a good set of pistons to use with this setup.. Daily driver, on 91 octane.
What pistons are you running right now? if stock gsr i would raise the compression a lil bit mayb some p30's my friend is currently running p30's in his gsr with skunk 2 stage 2 camshafts.. great numbers
you should be good as long as u bump up your compression wit some flat valves and 2-layer headgasket...my boy has that set up hittin 205 whp
If you get pistons, go with something like the wiseco set that put you just under 12:1 compression. Good compression for a street motor and nice relatively flat dome.
my .02
my .02
stonet149
12
Nov 2, 2008 09:29 PM
Collateral
Mar 25, 2005 09:56 PM
