power windows/locks into EK swap not working ... i need some help
i got SI door panels, window regulators, lock actuators, door harnesses, floor harness, and the underdash harness with the fusebox as well.
i finished putting in all the hardware with the rear half of the wiring about a month ago, and the windows were working just fine as they were supposed to. today i pulled the dash and swapped in the rest of the harness. now, my power windows no longer work, and the power locks don't work as expected; the passenger will lock automatically when i manually lock the driver door, moving the switch downward doesn't do a thing, and moving it up makes it unlock, lock, and unlock again. everything has been swapped from a 99-00 SI into my 99 DX.
if anyone has done this before, has dealt with any of these problems, or could simply shed some light for my poor civic, please help
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Fisrt I would go back and make sure all of the pins are making contact. Also make sure everything is getting power were it should.
still no repliess ??? :[
i'm planning to swap the power window relay with my friends to see if i can get the windows working again, since mine was damaged
now my car is throwing a CEL. i tried resetting it first, and after i started my car, the light came back on. I rented an OBDII scanner from AutoZone, and the display says
P0141 - O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
anyone know how to fix the lock/window problem, or the CEL code ??? please help me :[
Ek locks
Sep 6, 2013 12:42 AM
Brandeezy1
Sep 19, 2009 06:29 PM
ekx4
Feb 2, 2004 07:21 AM
