Problems with Starting...
Old Sep 17, 2006 | 06:36 PM
go4wheeling's Avatar
Default Problems with Starting...
Hello,
I have an 89 honda civic, Some times it will not start. I thought it was the fuel pump/filter because it doesnt always kick on when the key is turned to the on position, but I replaced the fuel pump and it still does it sometimes. Is there anything computer or electrical wise that anyone knows of that it could be?... anything that maybe tells the fuel pump to kick on?... The ground and the positive seemed to be fine to me. Has anyone else had this issue before?
THANK YOU
Old Sep 17, 2006 | 06:37 PM
'90crxSI's Avatar
Default Re: Problems with Starting... (go4wheeling)
Main relay
Normally located on the drivers side up underneat the dash on the side (behind the little coin holder thingy)
Old Sep 17, 2006 | 06:39 PM
'90crxSI's Avatar
Default Re: Problems with Starting... ('90crxSI)
try this
http://www.tegger.com/hondafaq/mainrelay.html
Old Sep 17, 2006 | 08:45 PM
The only thing with that is I hear all of the clicks that it talks about.
Old Sep 17, 2006 | 09:13 PM
salman's Avatar
just locate main relay,
Old Sep 17, 2006 | 09:18 PM
project midnight's Avatar
I had this exact same problem on my civ and i replaced the main relay and my fuel system worked fine. try it.
Old Sep 18, 2006 | 03:43 AM
thanks I'll try it.
916MINI
11
Aug 11, 2008 09:51 AM
nonbox
Jan 30, 2006 01:00 PM
Kaneo
Jun 24, 2005 08:43 PM
mgries
Sep 19, 2002 07:15 PM
RenoRacing
Sep 8, 2002 09:41 PM
