Which Oil?
Old Sep 17, 2006 | 06:31 PM
eye.ha8.u's Avatar
Default Which Oil?
I just did an oil change today and started wondering if I should use another brand or weight of oil.
I use Valvoline 10w-30, I get it at Wal-mart for 7 bucks for a 5 quart, and I picked up a fram oil filter. My engine is a B16a with stock internals, only mods are I/E and a chiped ECU.
Just wondering what all of you use, what your opinion is.
Old Sep 17, 2006 | 06:37 PM
Furyof4's Avatar
Default Re: Which Oil? (JayDeeEmm)
10w-30 is a little thick, I would change to 5w-30 at your next change.
FYI, fram filters are known by many as "the orange can of death".
Old Sep 17, 2006 | 06:46 PM
eye.ha8.u's Avatar
Hmm, I was told 10w-30 was the way to go, but acutally thought the same thing. I had never heard about the fram filters being bad, thought they were good.
Which brand of 5w-30 do you prefer along with filter?
Also just to throw in, I had thought the throw out bearing was going out, started to make a sound at certain RPMs, well when I went under my car today I seen that the heat shield covering the down pipe had cracked around the bolts and was partially hanging off, had my friend rev the motor and found out it was just rattleing as the engine shook from reving....
Thanks god that was alot easier of a fix!
Old Sep 17, 2006 | 06:48 PM
Xander teh Grate!'s Avatar
Redline oil and stock S2000 oil filter.
Old Sep 17, 2006 | 06:49 PM
Furyof4's Avatar
Ive always used Mobile One syn or Castrol dino oil but Havoline, Valvoline, Pensoil are all good. Really any SM rated oil should be ok.
For an overwhelming amount of info on oil, filters, fuel additives, etc...check out http://www.bobistheoilguy.com
Old Sep 17, 2006 | 08:57 PM
salman's Avatar
i uses,
Havoline Formula synthatic 20w-50,
But i am told to use it as i live in hot place.
Old Sep 17, 2006 | 09:43 PM
Zaakro's Avatar
Default Re: Which Oil? (Furyof4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Furyof4 &raquo;</TD></TR><TR><TD CLASS="quote">10w-30 is a little thick, I would change to 5w-30 at your next change.
FYI, fram filters are known by many as "the orange can of death".</TD></TR></TABLE>
It all depends on where you live. I live in So cal and they recommend 10w-30. You would use 5w-30 if it is cooler there than cali which it probably is. And just use Honda oil filters
Old Sep 18, 2006 | 05:03 AM
eye.ha8.u's Avatar
Default Re: Which Oil? (Zaakro)
I am originally from Socal, 626 area. I live in Kansas because of the Army and thats why I used 10w-30, its hot here in the summer just like cali but freezes in the winter, will switch to 5w-30 next oil change for winter.
Old Sep 19, 2006 | 01:08 AM
keepitngga1's Avatar
Valvoline 10w-30 with honda oil filter for my stock b16a
Moo-Moo
19
Aug 12, 2010 09:10 PM
tekniq
34
Jun 11, 2008 09:40 PM
o0oz
Feb 20, 2007 04:54 PM
EL'ation
Apr 20, 2003 06:37 PM
BAZ
Apr 14, 2003 10:29 PM
