Where did my oil go!?
Old Sep 17, 2006 | 05:42 PM
johnnyqsack's Avatar
Default Where did my oil go!?
Help! I've been checking my oil every week and I'm losing about 1/4- 1/2 qt of oil every week! There aren't any leaks in site. And I'm not seeing/smelling oil being burned. I checked under the car it's dry, same with around the engine. I'm using mobil 1. I have a 4cyl 97 accord, any ideas?
Old Sep 17, 2006 | 09:34 PM
sony224422's Avatar
Default Re: Where did my oil go!? (johnnyqsack)
take out a spark plug and see if you have any oil on it or in the hole. and check the drain plug on the pan and oil filter to make sure there both tight and not leaking when your driving. you could check the oil pressure sensor too.. i had a VW that leaked from that.
Old Sep 17, 2006 | 10:41 PM
iam7head's Avatar
Default Re: Where did my oil go!? (sony224422)
check the radiator, a bad headgasket could give you a leak and oil can be in the coolant.
look for milky/oily coolant
Old Sep 18, 2006 | 07:42 PM
Default Re: Where did my oil go!? (iam7head)
Well.. checked everything you guys said. Then, I got to my radiator.... It's milky and oily. I just replaced the radiator, could I have done something wrong there. Or can it only be a bad head gasket?
Old Sep 18, 2006 | 07:52 PM
sony224422's Avatar
i think it can only be a bad head gasket.. but head gaskets are easy to fix and there like $30 i do believe.
Old Sep 18, 2006 | 08:37 PM
ck123's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sony224422 &raquo;</TD></TR><TR><TD CLASS="quote">i think it can only be a bad head gasket.. but head gaskets are easy to fix and there like $30 i do believe.</TD></TR></TABLE>
their not easy to replace...........your probably talking about the valve cover gasket
Old Sep 18, 2006 | 08:41 PM
roblynn.org's Avatar
Default Re: Where did my oil go!? (ck123)
I don't know how much it would cost on a Honda, but I had a Mitsubishi, SHOC 4 Cyl head gasket replaced for around 600$.
There's a load of different charges, from what I remember, you've got the gasket sets (basically replace them all if you're tearing all the way down to it) then planing of the head(s), then putting back together, oil, coolant, et cetera.
Old Sep 18, 2006 | 09:01 PM
sony224422's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ck123 &raquo;</TD></TR><TR><TD CLASS="quote">
their not easy to replace...........your probably talking about the valve cover gasket</TD></TR></TABLE>
yup.. i was. sorry about that.. i was thinking about it after i posted.
NACE42
Mar 19, 2010 12:21 PM
littleblue
Oct 12, 2008 06:16 PM
qnealstevens1104
Acura TL, RL & ZDX
Nov 11, 2007 06:22 AM
peacexisxfree
Oct 3, 2004 10:18 AM
92hybridAccord
Nov 26, 2003 04:05 AM
