injectors
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 »</TD></TR><TR><TD CLASS="quote">preobd=low
obd1/2=high</TD></TR></TABLE>
you mean you understood what he was saying? I did not.
What are you two talking about?
it was a simple question IMO.
sounds like he has some injectors and he's not sure if they're preobd or obd1.
if you can't physically tell which is which you can put an ohmmeter across the coil and check resistance.
peak&hold preobd injectors will ohm out around 2 ohms and saturated obd1 injectors will ohm out around 11.
impedance=resistance
