p30 pistions in gsr block
Old Sep 17, 2006 | 02:26 PM
vtec-gorilla's Avatar
Default p30 pistions in gsr block
will a set of jdm p30 pistions work in a gsr block, and do i need to do any mofications to make them fit? if so how good are they performance wise?
Old Sep 17, 2006 | 02:30 PM
Brick Top's Avatar
Default Re: p30 pistions in gsr block (vtec-gorilla)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec-gorilla &raquo;</TD></TR><TR><TD CLASS="quote">will a set of jdm p30 pistions work in a gsr block, and do i need to do any mofications to make them fit? if so how good are they performance wise?</TD></TR></TABLE>
yes they will work in a gsr block. no mods. except maybe exchanging rods. they are the same bore as a gsr. and they raise compression a good amount. somewhere around 11:5 if not more. so yes they reveal good performance.
Old Sep 17, 2006 | 02:35 PM
Default Re: p30 pistions in gsr block (brick top)
what kind of rods will i need to get?
Old Sep 17, 2006 | 02:58 PM
Brick Top's Avatar
which crank r u using?
Old Sep 17, 2006 | 03:03 PM
Default Re: (brick top)
gsr crank,
Old Sep 17, 2006 | 03:04 PM
Brick Top's Avatar
then use gsr rods
Old Sep 17, 2006 | 03:16 PM
so the pistions will fit right on right. cause its a full jdm gsr block only thing wrong with it is that it needs new pistions and i have a set of p30 laying around and wanted to know if they will work
Old Sep 17, 2006 | 03:35 PM
Brick Top's Avatar
Default Re: (vtec-gorilla)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec-gorilla &raquo;</TD></TR><TR><TD CLASS="quote">so the pistions will fit right on right. cause its a full jdm gsr block only thing wrong with it is that it needs new pistions and i have a set of p30 laying around and wanted to know if they will work</TD></TR></TABLE>
yep, just have a machine shop swap the pistons.
Old Sep 17, 2006 | 03:40 PM
dmacaalay's Avatar
no problems at all. just slap them on with some new pistons rings and youll be fine.. doesnt matter which rings either, any oem 81mm b series rings will work..
Old Sep 17, 2006 | 03:57 PM
Default Re: (dmacaalay)
thanks u guys are the best
Old Sep 17, 2006 | 04:42 PM
Brick Top's Avatar
anytime
96civic808
Jun 1, 2010 01:30 PM
JdMhEaD
Feb 14, 2008 03:01 PM
hatchi
Northern California (Sales)
Jun 5, 2006 02:28 PM
92bseries
Feb 8, 2006 10:58 AM
m R g S r
Mar 18, 2004 08:49 PM
