CEL Help
Old Sep 17, 2006 | 01:31 PM
Eg Fool's Avatar
Default CEL Help
The car is a 1992 Civic Hatchback with a JDM D15B and PO8 ECU. My check engine light came on when I was at work today and stayed on. It drove fine for about 5 minutes then at a stop it bogged out and shut off. When I drove it home I couldn't shift past 3k and it was driving really slow. I am throwing a cylinder position sensor and IACV codes. I'm assuming that I now need a new dizzy and need to clean or get a new IACV. I want to confirm this with others before I make any moves. This is my daily driver and I need to have it back to normal as soon as possible. What is the worst that can happen if I continue on to drive with this for say about a week? I will try to catch rides as often as possible to avoid driving it. Your input is much appreciated. TIA
Old Sep 17, 2006 | 02:24 PM
Eg Fool's Avatar
Default Re: CEL Help (Eg Fool)
Nobody?
Old Sep 17, 2006 | 05:39 PM
Eg Fool's Avatar
ttt
Old Sep 17, 2006 | 07:00 PM
92ehatch's Avatar
clean the IACV and see if that helps. it could be that it went bad.
i *THINK* the cylinder position sensor is somewhere in or around the distributor, but someone else will have to chime in to help you with that
Old Sep 17, 2006 | 07:08 PM
hatchi's Avatar
try resetting the ecu first and see if it clears up. otherwise clean the iac then reset it again
Old Sep 18, 2006 | 08:07 AM
Eg Fool's Avatar
Default Re: CEL Help (92ehatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92ehatch &raquo;</TD></TR><TR><TD CLASS="quote">i *THINK* the cylinder position sensor is somewhere in or around the distributor, but someone else will have to chime in to help you with that</TD></TR></TABLE>
yes that is where it's located, i already know my dizzy is bad, i will hopefully have another one by the end of today and will clean my iacv and post results.
Old Sep 22, 2006 | 07:50 AM
Eg Fool's Avatar
ttt
need confirmation that the dizzy is my problem
Old Sep 22, 2006 | 07:56 AM
THC07's Avatar
need a dizzy?
any parts?
pm me
Old Sep 22, 2006 | 08:05 AM
Eg Fool's Avatar
Default Re: CEL Help (THC1107)
pm'd
Old Sep 22, 2006 | 05:44 PM
Eg Fool's Avatar
Ok here's the deal, I replaced the dizzy and I no longer have a check engine light. Now I start the car, and it still drives like ****, but now I can rev past 3k. It takes forever to get up to speed, bogs out really bad, my rpms drop below 500 and it stalls out sitting still. I tried checking for codes but my cel just stayed on and didn't flash, what does this mean? I tried changing ECU's and it did the same thing? Does anyone know what the problem would be?
Old Sep 22, 2006 | 05:48 PM
ExCon's Avatar
try the Gumout fuel system cleaner, you would be surprised!
Old Sep 22, 2006 | 05:54 PM
Eg Fool's Avatar
Default Re: CEL Help (NOjdmHERE)
So your saying that it is probably fuel? I was going to do that tommorow anc check my timing, any other suggestions?
Old Sep 22, 2006 | 06:01 PM
YodajdmEK4's Avatar
Check IACV, reset ecu, and check fuel!
Old Sep 22, 2006 | 06:02 PM
YodajdmEK4's Avatar
Default Re: CEL Help (YodajdmEK4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YodajdmEK4 &raquo;</TD></TR><TR><TD CLASS="quote">Check IACV, reset ecu, and check fuel!</TD></TR></TABLE>
Also double check ur wiring.
Old Sep 22, 2006 | 06:07 PM
Eg Fool's Avatar
How do you reset ecu? I cleaned my iacv and nothing dirty came out.
Old Sep 22, 2006 | 06:08 PM
YodajdmEK4's Avatar
Disconnect the battery for like 5-10 minutes
Old Sep 22, 2006 | 06:27 PM
Eg Fool's Avatar
Did, nothing changed. Thanks for all the help so far
I will be using fuel cleaner tommorow and see where I am after that.
Old Sep 23, 2006 | 01:48 PM
Eg Fool's Avatar
ttt
it rained today so i didn't get anything accomplished
91efbluehatch
10
Dec 11, 2011 04:37 PM
versatilezc
Jun 15, 2006 10:28 PM
benmasters
Dec 4, 2004 07:39 AM
CRX SiR T
Nov 1, 2003 08:26 AM
Bspec18
Feb 5, 2003 01:36 PM
