205/45/16 will it rub if drop with no gap?
Old Sep 17, 2006 | 01:19 PM
Hiroshima_VTi-S's Avatar
Default 205/45/16 will it rub if drop with no gap?
i want to run 205/45 series on 16x7 but also want to drop it (not tucked) but no gap between the fender and tire / will it rub turning or regular driving? thanks!
Old Sep 17, 2006 | 01:28 PM
vlc92189's Avatar
whatcar ? and no it shouldnt
Old Sep 17, 2006 | 01:36 PM
jdmztrane's Avatar
Default Re: (vlc92189)
It shouldnt, but I have 205/50/15 Dunlop Driezza's with 15x7 GT3s, with Tein S-techs and I rub a little. My front S-tech springs are from a DA Teg so it could be a little bit lower in the front than normal S-techs, but there aint no wheel gap!
I also had a little bit of an issue with the rear upper control arm (i think thats what it is) that would hit the clip on wheel weights when I would turn so I had to go with all stickies .
Old Sep 17, 2006 | 01:45 PM
Scrapin4DR's Avatar
Default Re: (jdmztrane)
it probably won't, i ran 205/40/16 fronts tuckin on my old civic, and it didn't rub, i also had 16x7
Old Sep 17, 2006 | 02:04 PM
M2S~Juan's Avatar
nope, should work fine
Old Sep 17, 2006 | 03:24 PM
DaveSi677's Avatar
Default Re: (juan671_M2S)
we do have a wheel and tire forum!
Old Sep 17, 2006 | 04:23 PM
egsi's Avatar
Default Re: 205/45/16 will it rub if drop with no gap? (Hiroshima_VTi-S)
I rub!!...and I'm on 205/45/16...but im about .5 inch tucked . The sound is horrible but i like the way it looks.... I believe you will only rub in hard cornering. I had 205/40/16 tucked to the rim and it didnt rub as bad as it does now. But the 45 series rides noticably better.
Old Sep 17, 2006 | 04:47 PM
by the way my car is 96 civic coupe
Old Sep 17, 2006 | 04:48 PM
Eran's Avatar
HT White Ops
On heavy bumps you'll hit your fender liner.
Old Sep 17, 2006 | 05:11 PM
cxSHOE's Avatar
Default Re: (Hiroshima_VTi-S)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hiroshima_VTi-S &raquo;</TD></TR><TR><TD CLASS="quote">by the way my car is 96 civic coupe </TD></TR></TABLE>
on the ek's it will rub. due to the inner plastic covering. on the eg's it goes straight up, on the ek's it starts out flat then goes up...
and turning along with centrifigul force and any road bumps during the turn you will rub with a no gap setup...unless your suspension is super stiff. i run 12k's and still rub. with a no gap setup.
Old Sep 17, 2006 | 07:25 PM
Eran's Avatar
HT White Ops
Also, on the EK, even without the fender guard, there is an ridge of the subframe rail where the metal joins, and that will cut into your tire if it rubs too high. I was running blades with 195/65/15's, and every time I hit a bump, I rubbed.
Old Sep 17, 2006 | 09:02 PM
Timmay's Avatar
Default Re: (Eran)
i have 205/45/16 with 16x7 and a H&R race drop on my 97 sedan and i dont rub at all.. i had some coilovers on for a while and i had it dumped and barely rubed. mainly when conering
Old Sep 18, 2006 | 05:31 AM
Eran's Avatar
HT White Ops
Default Re: (Timmay)
Did you still have the fender liner in? because that rib I'm talking about is on the underside of the frame rail, and gets covered by the splash guard. Check it out sometime, it's scary looking.
Old Sep 18, 2006 | 10:17 AM
Timmay's Avatar
Default Re: (Eran)
i have both spash gaurds
Brandeezy1
Jun 20, 2012 04:04 PM
zc_eg6
Jan 9, 2009 03:38 PM
PowerLeg
Nov 13, 2008 08:20 PM
Dgilmour
Apr 29, 2006 03:49 PM
darkcvc
Jun 22, 2004 11:17 AM
