HELP power oem headunit outside of car?
Old Sep 17, 2006 | 12:19 PM
teggsr925's Avatar
Default HELP power oem headunit outside of car?
i replaced the oem head unit from my car n forgot to take the cd's out of the oem 6disc changer, i need to power the headunit to power the changer to get them out
How can i power the headunit outside of the car?
I searched and nothing came up.
Old Sep 17, 2006 | 12:35 PM
umop-apisdn's Avatar
Default Re: HELP power oem headunit outside of car? (teggsr925)
I'm sure if you power the +12 and supply a ground it should be enough to eject the cds.
Old Sep 17, 2006 | 12:38 PM
02 accord's Avatar
The best and probably the easiest way would be to hook it back up in the car. You could also get yourself a plug that goes into the radio, and hook up the constant and accesory wires to +12v and ground the ground. But that would most likely be more work (finding the plug) and more expensive (paying for it).
Old Sep 17, 2006 | 12:43 PM
teggsr925's Avatar
Default Re: HELP power oem headunit outside of car? (umop-apisdn)
wat and wheres the +12, sorry i dont know much about electronics
Old Sep 17, 2006 | 12:47 PM
skingfreak's Avatar
The red post on your battery. AKA the positive on your battery. should work just fine. Unless you have and extra wire harness (the thing that plugs into the radio) it will be easiest to plug it back into your car, and eject them.
Old Sep 17, 2006 | 01:02 PM
teggsr925's Avatar
Default Re: HELP power oem headunit outside of car? (skingfreak)
wat should i plug that too n how
Old Sep 17, 2006 | 01:09 PM
teggsr925's Avatar
could i open up the headunit n power somewhere in there
Old Sep 17, 2006 | 01:17 PM
Ok, here goes. Get the cd player in question and look at the back of it. There is a 16 pin connector in the middle, you had to unhook it to remove the unit from your dash. On it are two rows of pins, one on top, the other on the bottom. The top has 8 pins in a 4-4 configuration, the bottom also has 8 pins in a 3-2-3 config. Imagine the top set of pins are numbered 1 through 8 numerically. Hook the 5th pin to the positive side of your battery. The ground (negative post on battery) will be hooked to a pin on the bottom row, on number 14. Imagine the bottom row is labeled 9 to 16 numerically.
A. I found all of this info in the Service Manual, so it's correct.
B. I hope you have your 5 digit security code to input when the unit is powered up. If not, you have to go to the dealer to get it.
:EDIT: Here's an illustration for ya:
Modified by umop-apisdn at 5:51 PM 9/17/2006
Old Sep 17, 2006 | 01:49 PM
teggsr925's Avatar
yo thx alot for that info, im gonna have to do that since i cant the new headunit out, its stuck
Old Sep 17, 2006 | 02:13 PM
teggsr925's Avatar
how would i conect the pegs to the battery? i took a wire n put in on the +12 peg n then on the + battery post, n it didnt power, do i have to have it grounded?
Old Sep 17, 2006 | 02:23 PM
Yes, you need the ground to complete the circuit.
Old Sep 17, 2006 | 02:29 PM
teggsr925's Avatar
tried that n nothin happend, n yes i had the car turned on
Old Sep 17, 2006 | 02:55 PM
I thought it would... So nothing came up on the display? It should have said "CODE".
Old Sep 17, 2006 | 02:56 PM
teggsr925's Avatar
nothing, im gon try again tho
Old Sep 17, 2006 | 04:29 PM
teggsr925's Avatar
i think i fried the radio, no power, but a few sparks
SpadedEK
Audio / Security / Video
Oct 14, 2009 07:02 PM
Blanket Jackson
Jun 9, 2007 05:30 PM
hatchinprogress
Mar 8, 2006 05:18 PM
That Sob
Nov 1, 2005 01:51 PM
professorman
Apr 19, 2003 11:13 AM
