Pasadena/CA: *** 1999 Turbo JDM H22a Fully Built Accord Coupe EX *** CLEAN!
1999 Honda Accord Coupe EX with 66k miles on the odometer. It has a Japanese H22 motor that is fully built from the ground up that only has 5.8k miles on it. This car is built perfectly and nothing done sloppy... my belief is that if you're going to do it, then do it right the first time. Working A/C and power steering, no oil leaks whatsoever. Please email me for questions. I have a LOT of extras that go with the car, some stuff is brand new (as listed below). Mobile: 626.372.2023 and ask for Danny. $12495 OBO, Im open to offers close to asking.
More photos at http://www.cpixel.com/album_vi..._evil
JDM PRELUDE H22A SHORT BLOCK ASSEMBLED WITH IRON DUCTILE SLEEVES
ARIAS 8:5 COMPRESSION RATIO PISTONS AND FORGED RODS
NEW HONDA GENUINE OIL PUMP
NEW HONDA GENUINE WATER PUMP
NEW HONDA GENUINE TIMING BELT
ARP HEAD STUDS INSTALLED
NEW BEARINGS, MICROPOLISHED AND BALANCED ENGINE BLOCK
TITANIUM VALVE SPRINGS AND TITANIUM VALVE SPRING RETAINERS
PORT FLOW - 3 ANGLE VALVE JOB (INTAKE/EXHAUST, SURFACE, HOT TANK, NEW VALVE SEALS)
R&R ENGINE TENSIONER, HEAD GASKET
DRAG GEN III TURBO KIT W/ INTERCOOLER, CUSTOM PIPING W/ HIGH TEMP PAINT CHROME PAINT
TURBONETICS HYBRID T4/T3 TURBO
TIAL 40MM WASTE GATE
GREDDY TYPE-S BLOW OFF VALVE
RC ENGINEERING 550CC UPGRADED FUEL INJECTORS
EARLS KEVLAR - 10 OIL RETURN LINE W/ AN FITTINGS
QUAFE (LSD) LIMITED SLIP DIFFERENTIAL TRANSMISSION W/ NEW BEARINGS AND SHIMS
CLUTCH MASTERS - STAGE 5 CLUTCH
WALBRO 255PSI IN-TANK FUEL PUMP (GOOD FOR 400+HP)
GREDDY ELECTRONIC 60MM BOOST GAUGE (SILVER)
GREDDY ELECTRONIC 60MM EXHAUST GAS TEMP GAUGE (SILVER)
GREDDY ELECTRONIC 60MM AIR/FUEL RATIO GAUGE (SILVER)
MSD IGNITION AMPLIFIER AND COIL
DENZO IRIDIUM IK24 SPARK PLUGS WITH ARAMAKI WIRES
HONDATA INTAKE MANIFOLD GASKET
KOYO 3-CORE ALUMINUM RADIATOR
DUAL HIGH-SPEED SPAL RADIATOR FANS (PULL TYPE)
HONDA H23 MOTOR MANUAL TENSIONER CONVERSION KIT
AEM EMS - STANDALONE ENGINE MANAGEMENT
AEM FUEL PRESSURE REGULATOR W/ GLYCERINE GAUGE (SILVER)
AEM ADJUSTABLE CAM GEARS
AEM TRU-POWER PULLEY SYSTEM (UNDERDRIVE PULLEYS)
AEM 2.5 BAR MAP SENSOR
AEM WIDEBAND UEGO O2 SENSOR CONTROLLER MODULE W/ GAUGE (UNOPENED)
AEM HIGH VOLUME FUEL RAIL
MOROSO HEADER AND EXHAUST WRAP (NEW DEI EXHAUST WRAP INCLUDED)
HKS - CIRCLE EARTH GROUND WIRE SYSTEM KIT
APEXi - N1 SERIES DUAL EXHAUST WITH CUSTOM 3" PIPING
BREMBO SLOT/DRILLED ROTORS (FRONT/REAR DISCS)
SPARCO TORINO 2 FRONT DRIVER/PASSENGER SEATS (BRAND NEW) W/ SPARCO MOUNTING BRACKETS
PHILIPS HID 8000K TEMPERATURE HEADLIGHT CONVERSION KIT (BRAND NEW IN BOX)
ACCORD HEADLIGHTS W/ BLACK HOUSING (BRAND NEW IN BOX)
SEIBON EVO CARBON FIBER HOOD
SPRINT 2.5" LOWERING SUSPENSION KIT INSTALLED (ADDITIONAL NEW COILOVER SET INCL.)
RACING HART TYPE C5 WHEELS - 18 x 8.5
PIONEER GEX-P7000TV TV TUNER SYSTEM CONTROLLER
PIONEER AVX-P7000CD ENTERTAINMENT SYSTEM W/ 7" LCD SCREEN
PIONEER DEH-P9300 CD/AM/FM PRIMARY HEADUNIT
Jo-Tek Concepts
Feb 23, 2007 07:21 AM
