Where can I buy the tool to cross hatch?
Old Sep 17, 2006 | 06:45 AM
elcangripapi's Avatar
Default Where can I buy the tool to cross hatch?
Im not sure if this is the right thread to put it in but I dont think it can go anywhere else.
I need a tool to cross hatch my cylinders but I cant seem to find this tool anywhere. Im not even sure of its actual name. If anybody can point me in the right direction as to where i can buy it I would really apritiate it.
Its a d16z6 with stock bore.
Thanks.
Old Sep 17, 2006 | 07:54 AM
dpaton's Avatar
Default Re: Where can I buy the tool to cross hatch? (elcangripapi)
You need a cylinder honing machine. Your local engine building machine shop has one. You can't get the precision required with the crap that chucks into a hand drill. It'ss worth the money to have it done by a pro with the right tools.
Old Sep 17, 2006 | 09:03 AM
blackb18c1eg's Avatar
Default Re: Where can I buy the tool to cross hatch? (dpaton)
you can get a ball hone at most auto parts stores or maybe rent one. its easy!
Old Sep 17, 2006 | 09:10 AM
BIGTUNA's Avatar
Ball hones are simple and cheap, just use a cordless drill on slow. Works nice for just freshing up the bore for new rings.
Old Sep 17, 2006 | 09:56 AM
mgags7's Avatar
is a handheld drill really a good idea to be honing your cylinders with??
at least something along the lines of a drill press would be better, that way you dont lean one way or the other accidentally....
Old Sep 17, 2006 | 09:57 AM
West Werks's Avatar
Default Re: (BIGTUNA)
http://www.brushresearch.com/I...s.htm
Old Sep 17, 2006 | 07:29 PM
dpaton's Avatar
Default Re: (mgags7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">is a handheld drill really a good idea to be honing your cylinders with??</TD></TR></TABLE>
Nope, hence the rec. to go spend the money at a machine shop. Besides, if all that's being done is a light hone, it'll be more expensive to go buy a crappy ball hone and spend the hours of frustration that will ensue (and then take it to a shop to get fixed) when it doens't come out right.
goatharper
Dec 21, 2018 10:37 AM
JDMDC5888
May 14, 2005 02:50 PM
Vsm Hatch
Jan 7, 2005 06:27 AM
CLICC916
31
Feb 18, 2004 10:19 PM
X2BOARD
Jun 4, 2002 09:48 AM
