car won't crank, main relay buzzing
Old Sep 17, 2006 | 06:42 AM
markviiisvt4's Avatar
Default car won't crank, main relay buzzing
I just did a b18a swap in my 91 rex. It was starting and running fine now all of the sudden the car won't crank any more the main relay is making a weird buzzing noise and the LED on the ecm is blinking eraticly in unison with the buzzing from the main relay. what the hell is up with that?
Old Sep 17, 2006 | 09:03 AM
Default Re: car won't crank, main relay buzzing (markviiisvt4)
ok i figured out he no cranking problem but the main relay is still clicking really fast and it won't start.
Old Sep 17, 2006 | 11:15 AM
I Have an STD's Avatar
wrenchin'
chek your grounds. then as you're cranking it, hit the dash with your fist right over the main relay. if the relay is the problem, the car will start
Old Sep 17, 2006 | 11:48 AM
i forgot to plug the driver side of the harness back in " doh"
Yuta
Jun 8, 2016 08:44 PM
nismogrendel
Apr 24, 2010 01:43 AM
A's 94 GSR
Jun 9, 2008 11:48 AM
SuM Honda
Nov 22, 2007 06:14 PM
95_red_dc
Nov 1, 2007 04:18 PM
