OBD0 to ODB1 conversion (LSVTEC)...searched now just need confirmation
Old Sep 17, 2006 | 06:11 AM
SYNSEI's Avatar
Default OBD0 to ODB1 conversion (LSVTEC)...searched now just need confirmation
Ok after searching I think I've narrowed down what needs to happen but I just want to make sure. I've never been good at the on board diagnostic side of things. Anyways, I just need a couple of things confirmed.
Setup is for my 91 LS w/ B16A2(OBD2) head.
To convert my car from OBD0 to OBD1, I'll first have to use the sensors from my LS head to make the B16A2 head work as OBD0.
Then get:
OBD0-to-OBD1 conversion harness
OBD1 distributor (TD-44)
OBD1 ECU - probably a P28 tuned by Phearable
4 wire 02 sensor - can probably bypass this with proper tuning
Ok. Can anybody confirm this info for for me?
Thanks in advance.
Old Sep 17, 2006 | 07:53 AM
SYNSEI's Avatar
Default Re: OBD0 to ODB1 conversion (LSVTEC)...searched now just need confirmation (SYNSEI)
Anybody?
All I need is a "Looks good." or a "You're wrong. "
Old Sep 17, 2006 | 01:46 PM
SYNSEI's Avatar
Default Re: OBD0 to ODB1 conversion (SYNSEI)
Tx3.
Old Sep 17, 2006 | 02:35 PM
SIXTY's Avatar
looks good
Old Sep 17, 2006 | 03:36 PM
SYNSEI's Avatar
Default Re: OBD0 to ODB1 conversion (SIXTY)
Thank you kind sir.
Old Sep 18, 2006 | 12:45 AM
SwappedTURBOegg's Avatar
you need a obd0 to obd1 dizzy converter plug
Old Sep 18, 2006 | 02:25 AM
SYNSEI's Avatar
Default Re: (SwappedTURBOegg)
I need a converter plug AND an OBD1 distributor? Please explain. I mean thats cool if I can keep my OBD0 distributor and just buy the conversion plug (cheaper), but your saying I need the plug and the new distributor...I'm a little confused.
Old Sep 18, 2006 | 09:50 AM
Furyof4's Avatar
Default Re: (SYNSEI)
No he means an obd1 dizzy won't plug into an obd0 harness. The dizzy conversion harness solves that.
Old Sep 18, 2006 | 04:28 PM
SYNSEI's Avatar
Default Re: (Furyof4)
Ok. Thanks bro.
Jul 4, 2009 09:18 PM
Faya
Engine Management and Tuning
Feb 16, 2009 07:40 PM
teggytegteg
Apr 16, 2006 12:11 AM
Ruby Civic
Dec 11, 2003 04:07 AM
Norcalstoppy
Oct 15, 2002 01:29 PM
