92 CX EG hatch Turbo!!!!
Mods
1992 Hatchback CX
Macco mercedes paint
Rota Sub Zeros
Falken Azeinas
H&R springs
tokiko gas shocks
clear corners sprayed amber
type R rear and front sway bar
APC lower tie bar
skank2 upper rear tower bar
JDM EG6 front tower bar
LS integera seats (front and rear)
JDM HOP console
Greddy turbo timer
Auto meter boost gauge and A/F ratio.
HKS EVC electronic boost controller
Dual bend short shifter
Poly shifter bushings
2 bumpers (one flat black that is cut for the intetcooler) the other is stock
MOTOR
JDM b16a
T3/T04e turbine turbonetics
Meduassa style mani (not SSautochrome)
Tial 38mm wastegate 10psi spring
Hondata s200b
DSM 450 blue tops(will throw in presicion 880cc)
3inch mandel bent exhaust
type R intake mani
Type R throttle body
hondata heatsheild gasket
SRP 9 to 1 pistons
ARP head studs
Eagle rods
micropolished crank and balanced
Stock sleves
SS ferra valves
skunk 2 springs and retainers
GSR cams
skunk 2 cam gears
MSD external coil
MSD dis 6 box W/ two step.
B&M fuel pressure regulator
GM 3bar Map sensor
The car has no carpet, no cargo cover, no spare tire. Car weight 2100 with a full tank of gas. Just had the whole royal purple fluid change. The speedometer is acting up and it wants to not work but will sometime adn it isnt the gauge cluster.
I am getting outta the game. Car is located near Seattle Washington.
any question please feel free to ask.
$8500 OBO
Thanks for looking!!!
Modified by homicydalboy at 11:42 PM 9/17/2006
Replica_Racer
Feb 11, 2010 08:46 AM
homicydalboy
Feb 23, 2006 01:26 PM
