How do u take off Coil-Over ??
You can take them off all in one piece. Under the hood there are two little nuts and one bolt (PUN not intended. LOL) around the perimeter of the strut tower. You take those out/off and then there is just one more bolt at the bottom of the strut. I would recomend using a air impact gun for the bottom bolts all around the vehicle. You basically just use these steps on all four struts. The rear upper bolts are located in the trunk behind the carpet. Getting the struts out after unbolting can be a little tricky. You may have to fight with them a little especially in the back but it is possible to remove them.
