2 rad fans??
Old Sep 16, 2006 | 08:33 PM
mugenhatchie's Avatar
Default 2 rad fans??
Alright, I have a GSR motor that I swapped into my ED. I removed the ac and replaced both fans with pushers mounted in front of the rad. My question is can i wire the two fans together (off the rad fan plug) so they both come on now that I don't have ac?? Right now I have one plugged into the A/C fan switch and only one comes on (the passenger side one comes on) I am assuming that the drivers side doesn't come on because I have no ac. So can I just splice into the rad. fan wires??? Thanks in advance!!!
Old Sep 17, 2006 | 02:04 AM
4thgenhtch's Avatar
Default Re: 2 rad fans?? (mugenhatchie)
You Could Just run the current Possitive temperature controlled Wire(+ of your current fan) To a Relay, Run A Nice sized wire directly from the battery( FUsed of course)to the relay for power, then out of the relay to both fans... If you need a little diagram or anything let me know..
angrysmileyface
May 12, 2018 11:24 AM
onunezp
Jul 2, 2015 01:41 PM
crxaddikt
13
Jul 29, 2010 02:59 PM
civickiller
Aug 11, 2004 10:42 PM
blah13
Jun 8, 2003 07:32 AM
