Unclipping the injectors
Old Sep 16, 2006 | 07:45 PM
94vtirozguy's Avatar
Default Unclipping the injectors
I am in process of removing the IM, and have just the bolts on IM and unclipping the injectors to go.
In the manual it does not show how to do this. Any tips ?
Old Sep 16, 2006 | 07:49 PM
98vtec's Avatar
moderator emeritus
Default Re: Unclipping the injectors (94vtirozguy)
pinch....pull
Old Sep 16, 2006 | 07:51 PM
thanks. the first one would not budge, just wanted to make sure
Old Sep 16, 2006 | 08:16 PM
ok after pinching the little metal clip points in on each side, and trying to pull them out, they dont budge
Old Sep 16, 2006 | 08:18 PM
All-Motor-Junkie's Avatar
the little metal thing arround the injector has to come off, im assuming u already did this but if not wiggle em out
Old Sep 16, 2006 | 08:35 PM
yep that was it... pulled the metal clip off, and they came straigh toff...
thanks
Old Sep 17, 2006 | 04:39 AM
SnlpeR's Avatar
you gotta pull the metal clips outward before you can pull the harness out of the injector
no pinching required...just something small and pointy to push the metal out of the slot
totsie7944
Apr 22, 2008 09:18 AM
infumis
Feb 8, 2007 03:46 PM
hondakevin21
Nov 3, 2005 02:26 PM
AlxSiR7
May 3, 2005 10:49 AM
ITR9788
Mar 26, 2004 11:55 AM
