b16 obdo swap
I would like to put a b16a obd0 into my 89 crx si. The b16 that I have does not have a complete wiring harness. Can I use the engine harness from my zc and will it clip into the sensors on my b16 or do I need to get a harness from a b18 integra engine ? By the way I have used the search but i am still unsure
use your stock mpfi si harness..Then add the vtec pressure switch,vtec solenoid,knock sensor,and 2nd o2 sensor wires into your harness,then pin those wires here http://www.ff-squad.com/tech/w...1.jpg
you can make life easier by just getting a vtec subharness
ElectronED9
19
Nov 3, 2009 12:22 PM
EFinSi
Aug 12, 2007 09:53 PM
freeeked
Aug 30, 2003 02:27 AM
