Where to hook "VSS" wire on a 2000 accord coupe
Just as the title says, im confused as to where you are suposed to hook up the VSS wire. i know its not necisairy but i figure why not hook it, makes navi more accurate. But i dont know here to hook it up. Thanks! i guess stating that im trying to hook up a pioneer AVIC-D1 would help
Modified by skingfreak at 6:39 PM 9/16/2006
DIRECTWIRE™ WIRING INFORMATION - HONDA / ACCORD / 2000 / Accessory
[PRINT THIS PAGE]
12volts white + ignition harness
Ignition black/yellow + ignition harness
Parking Lights+ red/black driver side fuse box
Parking Lights- red/yellow steering column
Notes: Only available on the EX model.
Headlight blue/red - steering column
Trunk/Hatch Release white/red + drivers kick panel
Power Sliding Door
Speed Sense blue/white ECM
Notes: Located at the first plug on the ECM, it is a 32 pin gray plug. The ECM plugs can be accessed by pulling up the carpet on the passenger side of the center console. There are 4 plugs total.
Wipers
LF Window up/dn red/yel - red/blu A drivers door switch
RF Window up/dn blu/wht - blu/yel A RF window switch
LR Window up/dn red/yel - red/blu A LR window switch
RR Window up/dn red/yel - red/blu A RR window switch
[PRINT THIS PAGE]
Power Sliding Door
Wipers
http://www.the12volt.com/insta...ruise on the first plug, [gray 32 pin] of the ECM, accessed by lifting up the carpet on the pass. side of center console
94
94
TwoFaced
Dec 16, 2010 05:34 PM
EM2ner
Audio / Security / Video
Feb 10, 2007 04:48 AM
