removing p/s and a/c
Old Sep 16, 2006 | 12:06 PM
GoldCoin's Avatar
Default removing p/s and a/c
searched but no results.
can someone tell me step by step on how to remove both p/s and a/c on 94 ls
Old Sep 16, 2006 | 01:00 PM
god.loves.ugly
Guest
Posts: n/a
Default Re: removing p/s and a/c (DC TWOin IT)
Drain the AC stuff make sure you don't breathe it in. remove the ac compressor and bracket remove the power steering pump and bracket pull the hose off the power steering fluid reservoir plug it or drain it. remove the hoses off the steering column I would take a hose and loop it from the "inlet" to the "outlet" so they are not left open then clamp that hose on, it will also keep the power steering fluid that is in there inside it so that it doesn't dry up, which will make steering a little easier.
Old Sep 16, 2006 | 02:27 PM
GoldCoin's Avatar
Default Re: removing p/s and a/c (god.loves.ugly)
thx
ken2830
Jul 30, 2006 12:40 AM
pumafeet10
Oct 29, 2004 06:14 PM
e13ctron
Jul 24, 2004 06:11 PM
magic hat #9
Jul 15, 2003 09:23 AM
rurkster
Oct 31, 2002 07:31 PM
