4 wire obd1 O2 sensor question?? HELP
Old Sep 16, 2006 | 12:02 PM
Jschnatter's Avatar
Default 4 wire obd1 O2 sensor question?? HELP
Ok, I need to hook up my o2 sensor. 1996 obd1 b18b...
coming from the exhaust/O2 sensor:
2-black
1-green
1-white
I cannot find a plug with these color wires... There is only one other square 4-wire plug and it has:
white/red
yellow/black
red/black
gree/blue
IS THIS THE CORRECT PLUG?? and if it is which wires hook up where?... i need to lengthen the wires so i need to know where each wire goes... thanks for the help!!!
Old Sep 16, 2006 | 02:09 PM
Jschnatter's Avatar
Default Re: 4 wire obd1 O2 sensor question?? HELP (Jschnatter)
BUMP
Old Sep 16, 2006 | 02:30 PM
nsxmatt's Avatar
That plug should be correct as the colors on the o2 are not the same as the plug.
yel/blk - A25 - 12V switched
org/blk - A6 - O2 heater control
grn/wht - D22 - sensor ground
wht/red - D14 - O2 signal wire
That is what each wire goes to but unless you have the diagram that comes with the o2 I can't tell you which of the black is which.
Old Sep 16, 2006 | 03:42 PM
Jschnatter's Avatar
Default Re: 4 wire obd1 O2 sensor question?? HELP (nsxmatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxmatt &raquo;</TD></TR><TR><TD CLASS="quote">That plug should be correct as the colors on the o2 are not the same as the plug.
That is what each wire goes to but unless you have the diagram that comes with the o2 I can't tell you which of the black is which.</TD></TR></TABLE>
AWSOME! thanks man!!
jDMJeRk
Oct 3, 2019 08:19 PM
got_no_sol
Sep 26, 2016 08:26 AM
TheMechanic84
10
May 20, 2012 07:19 PM
Jschnatter
Sep 16, 2006 02:10 PM
