vss
Old Sep 16, 2006 | 11:55 AM
mugenwannabe's Avatar
Default vss
are all vss interchangable on 88-91 d series trannys?
Old Sep 17, 2006 | 08:09 AM
bump
Old Sep 17, 2006 | 08:34 AM
philkehn's Avatar
Im not sure on D series, i think that cable vss on the d series are built in so you would have to get a whole new tranny to convert to electric ( I may be wrong) I know that you can change out the unit from electric to cable on a b series for I have changed that around on my own vehicle and it works great, just cant get rid of the vss
Old Sep 20, 2006 | 09:31 PM
gsxr1k05's Avatar
the cable vss is not built in on the d series trans. you have to unscrew a bolt that holds the vss hold down tab. they all will come out.
Old Sep 21, 2006 | 03:56 AM
crxnj's Avatar
Default Re: vss (mugenwannabe)
you mean the actual drive gear in the tranny? from what ive seen its all the same **** 88-91 civic/crx manual tranny.
Old Sep 21, 2006 | 05:02 AM
D95si420's Avatar
not sure if u can tos a manual one in a auto trans and vice versa, but most any d-series VSS will work in its respective transmission, I have swapped in electronic VSS's for engine and guage cluster swaps plenty of times. and pulled electronic for cable vss's for the same reason.
Old Sep 21, 2006 | 11:14 AM
philkehn's Avatar
The d series speedos dont have the 2 oil hoses that run to it from what ive seen..
Heylookits shawn
May 21, 2007 09:36 PM
Rywire
Oct 9, 2004 05:11 AM
johnzm
Aug 30, 2002 09:32 PM
