Turn Signal Wiring Diagram?
So a while back somebody jacked my clear corners and decided that it was easier to snip my wiring and take the light assembly than to just remove the lights from teh assembly... I bought replacement wiring harnesses etc. and connected the wires as I thought might be right... now my turn signals just look kinda funny and it's a combo of wiring and non working bulbs.
When I turn the headlights on, on one side the front main bulb turns on and the side bulb does not, on the other side the side bulb turns on but not the front main bulb. Both main bulbs work though since my turn signals actually operate correctly by flashing the main bulb.
So first I'm wondering, what is the correct way the turn signals should turn on with the headlights on (I haven't seen a 98+ with it's headlights on in a while), and if someone has a wiring diagram so that I can hook it up right...
thanks in advance.
thanks in advance.
Wow, people are too cheap to get their own clear corners? Those people have no respect for your property. I hear people steal sidemarkers too (lame
). Good luck with the wiring!
jdm_ek_noob
12
Apr 8, 2014 04:10 PM
SiR Inspired ED7
Sep 18, 2005 04:48 PM
