Tranny swap reverse problems
Old Sep 16, 2006 | 06:28 AM
prcivic91's Avatar
Default Tranny swap reverse problems
I have a 91 civic the originally had a 4 speed manual it was swapped out to a si tranny by th last owner. now it the car is in reverse ad you turn it off with the clutch down, it will not turn off. It stays on and run until you remove it from reverse or remove the clutch. What could be wrong?
Old Sep 16, 2006 | 10:01 PM
prcivic91's Avatar
Default Re: Tranny swap reverse problems (prcivic91)
has anyone hear of these or ran into this before
Old Sep 16, 2006 | 10:38 PM
C1CRX's Avatar
Traffic signal tech
reverse sensor on top of tranny its easy to change if i remember correctly it has 2 bullet style connectors one green and one black just disconnect those and use a 19mm size wrench to remove the sensor from the tranny.
Old Sep 16, 2006 | 10:52 PM
E_F_9's Avatar
why do you turn it off in reverse?
Old Sep 17, 2006 | 02:53 PM
prcivic91's Avatar
Default Re: (E_F_9)
it just happened one and I check it out and found out these problem. it was like an accidental thing
ek4si
Transmission & Drivetrain
Jun 13, 2012 06:45 AM
ftrms
Mar 5, 2009 06:23 AM
Cractos
11
Aug 26, 2004 10:33 PM
boi-alien
Jul 4, 2003 12:49 PM
spladam02
Dec 9, 2002 06:05 AM
