Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
problem with my springs.
Old Sep 16, 2006 | 01:25 AM
03redEM2's Avatar
Default problem with my springs.
ok. so i put the front springs on my car. not a problem. didnt get a chance to start on the back springs cuz it got way too dark. so i take it for a drive around the block to make sure i dont hear anything funny. when i was turning i heard a weird sound. i take it back to the drive way and look at the spring while turning the wheel and the spring was turning also as i turned the wheel making a ******* nasty sound. does anyone know what i could have done wrong or anything i should check for???
Old Sep 16, 2006 | 01:51 AM
Miracle's Avatar
Default Re: problem with my springs. (03redEM2)
What kind of noise is it?
Old Sep 16, 2006 | 03:13 AM
toyomatt84's Avatar
Sanji
Might be your CV's knocking from dropping the hub too quickly. It might also be that the springs aren't sitting on the perch correctly, and are making a cracking noise.
Old Sep 16, 2006 | 09:49 AM
03redEM2's Avatar
Default Re: problem with my springs. (.Red.EM2)
well when my friend turns the wheel. it sounds like a popping noise. when i look at it the spring it is popping back and forth like it isnt tight enough but it is. sorry very hard to describe. any more info would be helpful gonna try to fix it today
Old Sep 16, 2006 | 10:04 AM
Todd00's Avatar
I said I don't want a title!
Chances are you assembled the front strut incorrectly at the top. Take them back off and make sure. Usually just lowering springs don't cause noises unless you assemble them wrong.
Old Sep 16, 2006 | 11:40 PM
Borokazan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 03redEM2 &raquo;</TD></TR><TR><TD CLASS="quote">well when my friend turns the wheel. it sounds like a popping noise. when i look at it the spring it is popping back and forth like it isnt tight enough but it is. sorry very hard to describe. any more info would be helpful gonna try to fix it today</TD></TR></TABLE>
damn, welcome to my nightmare. my coilovers have been doing this forever. turns out i need an adapter bearing to go onto my stock mounts that are made out of plastic or something. this **** is weak.
Old Sep 17, 2006 | 10:20 AM
skipbarber's Avatar
sounds like your upper mounts arent on there right. and make sure the ***** inside the bearing race didnt fall out...the very first time i lowered my car i backed my car out just to see a whole bunch of grease covered ***** in my driveway. live and learn..
Old Sep 17, 2006 | 07:09 PM
tak1civic's Avatar
ther's an arrow on the upper rubber mount where ur springs goes it has to face outward i had the same problem wit mine so just take the springs back out and position the top mount right and it should fix the problem..............
Old Sep 19, 2006 | 06:41 PM
slwh22accord's Avatar
I just put stock springs back on my 01 Civic. I am having a similar problem it sounds like. When I turn the wheel, I am hearing a popping noise from both sides. I will take a better look at it tomorrow.
Old Sep 20, 2006 | 06:01 AM
devani's Avatar
Default Re: (slwh22accord)
DUD your installation was not correct..
http://www.7thgencivic.com/for...86545
Do this and you should have no problem....
Old Sep 21, 2006 | 12:44 PM
scotteh's Avatar
make sure they were installed right, I had the same exact noise, and it turned out that my springs were installed upside down ftl
Old Sep 21, 2006 | 05:46 PM
Thanks Devani
Fixed my problem, good as new!
Old Sep 22, 2006 | 09:52 AM
devani's Avatar
happy motoring..
Old Sep 22, 2006 | 01:53 PM
lowinc's Avatar
good to hear
Old Oct 3, 2006 | 09:43 PM
jnav609's Avatar
what did you end up doing?
Old Jan 13, 2007 | 06:04 PM
7th Generation Civic's Avatar
Default Re: (devani)
i have the same popping noise problem with my 2001 civic on the driver side, could it be the spring?
Old Jan 13, 2007 | 09:45 PM
Sean DM's Avatar
Sounds like your top mount bearings.
Old Jan 14, 2007 | 05:56 AM
Newborn_'s Avatar
Grace Under Pressure
I had a whole world of problems with this too... I'd say Sean DM might be right on this one.
Old Jan 15, 2007 | 05:16 PM
Sean DM's Avatar
Default Re: (ONLYuk7thGen)
whoohoo finally!
Old Jun 21, 2007 | 07:53 PM
DynastyRacer22's Avatar
Default Re: (Sean DM)
yeah mines made the same noise until i found out my top strut bearing needs replacing
Old Jun 21, 2007 | 07:54 PM
awang's Avatar
Default Re: (DynastyRacer22)
um... this thread is like 5 months old...
Old Jun 21, 2007 | 08:25 PM
Default Re: (awang)
^oops haha im hella late
Old Jan 29, 2008 | 06:14 PM
silverride's Avatar
Default Re: problem with my springs. (Miracle)
I have a 03 ex and had the same problem.I replaced the bearing perches and still it did.then I procrastinated and then just realized three day's ago that it was gone.
I'm thinking they settled.
Old Jan 29, 2008 | 08:47 PM
PandaEm2's Avatar
hmm, seems like a lot of people had problems with spring installation on their em2.
(including myself) but we fixed it the same hour haha
Old Feb 9, 2009 | 01:49 PM
efaCiviC30's Avatar
i replaced my bearing in mine but i also have that popping noise still.
